#31
andrewlim8
Posted 12 February 2009 - 09:48 AM
Yes....I guess it stays a lot cooler in there
most of the time, battery located in the boot can easily lasts for at least 3 to 4 yrs.
#32
cheuman
Posted 13 March 2009 - 08:47 AM
Hi Guys,
You all should try this:
For US$39, it can extend your car battery life 2x to 3x. Really worth the investment.
http://duoregen.com/pulse.htmWorth trying.
#33
benny1001
Posted 16 March 2009 - 12:48 PM
Hi Guys,
I'm also using Delkor din 66 on my car(04 Audi A4 1.8T), not a Volvo but I think the " hot environment" of the engine bay should be about the same as S40 or even worse, will see how long it can last for...
BTW, my original battery is a lot bigger than the din66 I'm using now, but the shop I went didn't have that kind of big battery and so I chose to use the din66, it runs ok till now, can't feel the difference.
#34
V406198
Posted 16 March 2009 - 03:26 PM
most of brand new contil cars came with Din72 battery originally , but this is unpopullar size locally so most owners settle with down size battery instead ..
2004 S60R. AT. Tit Grey. Nordkap. 18" Pegs. TME SportCat Exhaust DP & Cat Back System. TME Lower Spring. Garrett GT3071R. RC 750cc Injectors. FMIC. K&N Filter. Pegasus 3" CAI. IPD HD TCV. IPD HD Ignition Coil, IPD 25mm Front Sway Bar. UR Custom 23mm Rear Sway Bar. UR Front & Rear Strut Bars. Stainless Steel Brake Hoses. Audi TT DV, Saab 900 ATF Cooler. TkiMotorSportRacing & IPD HD Link Rod. H&R 5mm Front Wheel Spacer. Endless Sport 0-400 Front Brake Pad. ScangaugeII Diagnostic Gauge. Stages 2 Snow Performance methanol Injection.
