r3xt0n
Posted 08 July 2011 - 03:28 PM
Bro, what is in the service kit? My turbo's turbine has nicks. Thinking of just replacing the compressor wheel/turbine...only.
It include more than 10 components replacement but not including compressor wheel/turbine because its replacement got to be done on special machine by specialist. Will post the info later once we have work out the details.
rx270xdi
Posted 09 July 2011 - 09:27 AM
hi bro,
have you fit in your improve bigger turbo? how is the performance?any lag at lower rpm? cruising speed? effect on consumption? and performance above 3500rpm?
Hi Bro,
Not yet to install the turbo, due to busy on my work, will update you once is fix...
rx270xdi
Posted 09 July 2011 - 09:33 AM
Hi Bro,
Is it the compression wheel or the turbine wheel..? the wheels is exclude in the service kits, but i have a used compression wheel.
tkw138
Posted 19 July 2011 - 12:49 PM
Hi Bro,
Bro rx270xdi,
It is the compression wheel in the air intake hose side. As long as in good condition, please bring it along to our coming TT.
If you can get a stronger wheel for me, even better.
Thanks
neonlee
Posted 19 July 2011 - 08:25 PM
Supprise me when i saw my old turbo...
Bro, your enhanced turbo with A/R.42, whats the A/R for our ori turbo ?
rx270xdi
Posted 19 July 2011 - 08:50 PM
Bro rx270xdi,
Thanks
Hi Bro,
Should be ok i think, anyway i bring it along to the coming TT, if there is no sudden activities. What is your meaning of Stronger wheel..? Higher flow rate..? If higher flow compression wheel, you may need to machine your turbo compression housing.
rx270xdi
Posted 19 July 2011 - 08:53 PM
Yes Bro,
Actually the whole unit stil remain the same, is just only to machine the Compression Housing to suite the bigger compression wheel. The A/R.42 is my old turbo, re-touch up and balance the wheels...
