vishant
Posted 27 February 2011 - 10:11 PM
vishant
Driver
u can find it by asking around spare part shop.I must say that not all will carry stock so do ask if they car order from u.
If u dont mind spending a little more, order from service center.
On the auto light,If the shift is smooth
1. check your battery terminal.
2. How old is your battery?
I hav experience where dying battery causes the auto light to lit up when driving in a jam.
Most probably bcoz not enough amp is supplied to the whole system.
As soon as it gets above 1500rpm, the light turns off as the alternator is supporting the current load.
yes it is possible that gunnerzz is right cause i had this experience before but the problem was after i change the battery everything seem to fine for couple of months but then problem came back . however after installing a voltage stabilizer this somemore or rather did the trick and starting the car also was easier..
Vishant selvarajah
turnip
Posted 01 March 2011 - 09:49 AM
welcome to the dark side TS.When you know how to maintain ur 1.8, you'll be lovin it.
as a human you must seek for the truth
Waja 1.8XEngine : F4P 771 auto(same as Renault Laguna II)
Spark plug : Should be the default "Champion RFC 87YCL opening 0.9" but using some cheapo spark plugs now =_="
Fuel System : Sagem S2000
Torque (x / o.min) : 170Nm/3750
Top speed (km / h) : 198
0-100 km / h (sec) : 11
Air Filter : Stock(gonna change to K&N as recommended by brother Arazakmy)
Gunnerzz
Posted 02 March 2011 - 09:36 PM
Yes u will be lovin it until..........
u got summon for overtaking on double lane because the car has the power to do so.
turnip,
if the radiator fan did not run if the aircon is off, whats the problem?
I hav try switching the relay but its the same.
vishant
Posted 02 March 2011 - 09:57 PM
vishant
Driver
turnip,
haha thats a good one and even bmw 3 series turn their heads when they see you flashing them off to the left..lol. radiator fan not running , what the temperature at that time .
Vishant selvarajah
Gunnerzz
Posted 02 March 2011 - 11:52 PM
If the aircon is off, the temp will soon kept rising to the red line.
When this happen, if i switch on the aircon, the fan will straight away run on its high speed meaning its not just for the aircon but for the radiator as well.
I hav to switch on the aircon as its the only way to make the fan run.
Now, the aircon is kept on 100% of the time.
vishant
Posted 05 March 2011 - 12:08 PM
vishant
Driver
bro i suggest you take it to renault and make them run a diagnostic test on the ecu and trust me the errors that they get are more reliable and accurate compare to protons test.. i had a common problem with the radiator but what i suggest you do it you know the thermostat near the fan just take it out and try cleaning it cause you see bro actually right if the temperature rises very fast then drops most of the time its just the thermostat.. it work for me hopefully for you too
Vishant selvarajah
MyProps
Posted 06 March 2011 - 01:21 AM
Just bought a second hand 1.8 AUto Waja last week. Really disappointed. First AUTO icon will on suddently and car become slow.Seems like gear stuck on that. This morning just found that front passenger side carpet wet after drive at raining day.Sometime Driver site lagi can hear sound like besi hit besi .ANyone can help???? i'm new to waja ....... and i only drive for 1 week....... ... problems
Solenoid Valve
arazakmy
Posted 06 March 2011 - 10:35 PM
Solenoid Valve
Happy motoring
MY WAJA 1.8 STILL MOVING STRONG
turnip
Posted 07 March 2011 - 10:57 AM
turnip,
I got summons already, although my car is at renautech.Strange huh?
Never did occur to me though, so don't really know. Just that when my temp rises is because of the radiator's hose cracked.Replaced and refill coolant.Done.
So how's the car nw?Any updates?Share problems here and so.
Posted 07 March 2011 - 11:14 AM
mfj
Driver
Happy motoring
haha...my 1.8 also strong enough
