Waja 1.8 Auto Problem 2003
Posted 08 February 2011 - 11:51 AM
Posted 08 February 2011 - 08:15 PM
Waaa...u brave enough to venture into the dark side by choosing the 1.8.
U should hav ask opinion from someone whom know the car b4 going for it.
On the Tranny light, when was the last time the ATF is change?
If u are not sure, flush the tranny.
Worst case is a solenoid valve needs to be replace.
When does the sound on the driver side happen?Where is it coming from?
Posted 09 February 2011 - 09:31 AM
i'm not sure when's the ATF change. It's only some time AUTO Icons will on.then car just stick on 1 gear.Carpet on Passenger sit beside driver wet can effect? besi hit besi sound under driver side once u pass black and white lines can hear clearly.how much estimate cost to repair it?
Posted 09 February 2011 - 04:00 PM
should have join autoworld first before u purchase any car...
Human Resource Solutions
We provide a comprehensive range of Human Resource (HR) management solutions
Posted 09 February 2011 - 04:32 PM
Well then its a wise choice to change the ATF. Only use ELF Renaultmatic D3 Syn.
Wet carpet can make your car smell. Go hav it fix asap. rust oso can occur.
The besi hit besi sound is probably worn out bushes or the handbrake cable bracket.
U can DIY check by shaking all the joints. None of it should move when u try to shake them.
Posted 26 February 2011 - 10:02 AM
Posted 27 February 2011 - 11:20 AM
Posted 27 February 2011 - 01:04 PM
I would normally warms the car up before driving off in the morning. If the GB Auto icon still appear (normally if there is a sudden change of gear - up or down) , stop by the roadside, switch off and start engine again, normally then ok.... my car la...
My mech told me that it may be due to GB oil pressure which is still not sufficient.
Just ensure mech is familiar with the car (Renault), otherwise the tendency of trial and error mech which will bring you nowhere.
Mine is Wan of Perfection Garage, Subang Bistari. Few others in Subang and Puchong I think.
Wet carpet most probably also due to windscreen previously changed and not properly done resulting rainwater seeping through it - just 2 cents...
Posted 27 February 2011 - 05:44 PM
Posted 27 February 2011 - 08:24 PM
u can find it by asking around spare part shop.I must say that not all will carry stock so do ask if they car order from u.
If u dont mind spending a little more, order from service center.
On the auto light,If the shift is smooth
1. check your battery terminal.
2. How old is your battery?
I hav experience where dying battery causes the auto light to lit up when driving in a jam.
Most probably bcoz not enough amp is supplied to the whole system.
As soon as it gets above 1500rpm, the light turns off as the alternator is supporting the current load.
