You can practice that on large corner/curve, it provide similar effect. Try the difference between both methods, you will feel firmer and better ground holding when you are on lower gear with slight acceleration.
A Sudden Encounter With Puddle Of Water
Posted 12 December 2010 - 12:38 AM
Posted 12 December 2010 - 01:25 AM
Its worst if its dark as the puddle will look the same as the road surface.
This is what i do:
1) brake b4 the puddle and let it go b4 reaching the puddle.
2) both hand on steering
3) counter steer when needed.dont put too much input,just enough to head the car to the right direction.
It was nerve wrecking on the 1st 2-3 puddle but it turn into adrenaline pumping action when u got use to it.
As long as u dont go too fast u wont die.
Posted 13 December 2010 - 12:18 AM
Posted 13 December 2010 - 01:08 AM
i wondering last time, koh was doing 180km/h+- is it? while hydroplanning...
Human Resource Solutions
We provide a comprehensive range of Human Resource (HR) management solutions
Posted 13 December 2010 - 11:28 AM
koh's 4 tyres were floating on water... lucky he learnt how to drive boat before...
Posted 13 December 2010 - 11:39 AM
lucky can avoid head on collision direct to divider....
even that rear bonnet and front oso wrecked....
(NFS Underground)
Posted 13 December 2010 - 02:04 PM
If got ABS then not a problem. If without, then just lift of the throttle and you will slow down especially at 50 to 80kph only.
Even if faster, never lock your brakes as you will skid and there is no control even if counter steer a FWD. Once you let go the brakes it is easy to counter steer especially for FWD.
With the tyres I use, I normally go faster in the rain............
Posted 13 December 2010 - 06:55 PM
how come go faster?? floating liao ar...
Posted 13 December 2010 - 07:26 PM
Don't you read the whole sentence? With the tyres I use, I normally go faster in the rain, means I am using wet traction tyres....
Posted 13 December 2010 - 08:20 PM
of course i did. that's why i'm asking whether you're floating. taya botak ma.. lol
