Hi Bros,
This oil is more suitable for our Rexton 270XDI, Meeting MB sheet 229.1 and latest API CI-4.
Titan HPE Ultra 15W40
Super High Performance Diesel Engine Oil for the most demanding requirement.
TITAN HPE ULTRA 15W40 is a long-life all season SHPD universal engine oil for high performance engines requiring the latest API performance in combination with top-tier ACEA specifications.
Specifications:
√ API CI-4/CH-4/CG-4/SL
√ ACEA E5/E3/B4/A2
√ GLOBAL DHD-1
√ MB 228.3/229.1
√ MAN 3275
√ VOLVO VDS-3
√ CUMMINS 20078
√ Mack EO-M+
√ MTU Oil Category 2
√ RVI RLD
√ CAT ECF-1
Benefits:
· Long-life SHPD oil has ample reserves to cope with extended oil change intervals.
· Enhanced anti-wear characteristics.
· Provides effective protection against piston ring wear, rust and bearing corrosion.
· Optimised cold start and fast warm-up.
· Good oxidation resistance and reduced varnish, lacquer, sludge and carbon deposit formation even in severe service operation.
· High lubrication oil film strength protects heavily loaded valve train gears.
· Protect against bore polishing, scuffing and minimizes cylinder liner wear.
· Excellent dispersancy retains soot and harmful oxidized products in suspension, aids filterability.
· Good reserve alkalinity retention effectively neutralizes harmful acidic combustion contaminants and prevents premature wear in pro-longed oil service interval.
· Good viscosity-temperature behaviour due to stay in grade characteristics even in very severe conditions.
Application:
· TITAN HPE ULTRA 15W40 is recommended for major US, European and Japanese diesel engines such as Caterpillar, Cummins, Detroit Diesel Allison, Volvo, MAN B&W, MTU, Duetz, Wärtsilä, MB, Komatsu, Hino and others.
· Developed for highly stressed normally aspirated and turbocharged diesel engines with exhaust gas recirculation (ERG) system.
· Ideal all-season oil for mixed fleets, construction and earth moving equipment, marine ferries and industrial equipment with diesel engines.
· Can be used in gasoline engines requiring API SL engine oils.
Pack In 18Pail
Engine Oil For Rexton
rx270xdi
, Oct 06 2010 02:36 PM, 2 replies to this topic
Posted 05 November 2010 - 08:50 PM
Created this thread to share details, spec and discussion on Engine Oil for Rexton. Transfered some old posts related to this over here.
Posted 10 November 2010 - 12:13 PM
Most workshop can perform engine oil change if you bring along the required tool and the right Engine Oil & Oil Filter.
Cost Saving
If you change Engine Oil & Oil Filter at SC that will cost easily RM250~RM300 whereas you easily save about 50% thru Group Buy by RextonHub and pay a small fees (most charge RM10~RM20) to change them at outside workshop.
1. Engine Oil Suction Machine to suck engine oil directly without having to release from underneath. It provide better drainage too and also faster.
2. Hose dip into engine to suck engine oil.
3. Special Oil Filter Cap Opener that not available at most workshop. Should carry your own if going to normal workshop for engine oil changing.
Cost Saving
