byebye2u
Posted 06 September 2010 - 09:20 PM
Tat crazy mannnn.... How much each gbox cost u? Maybe u shuld change to manual lah...
kancil la bro, gbox so cheap from half cut shop..hihi..1st standard but always 90 km/h 2nd gear..hahahaha then turbo..then uprade somemore until out meter..later kenari, same also..now no more, just drive slowly 2 1/2 hours KL/Penang only..hihihihi
r3xt0n
Posted 01 October 2010 - 01:55 AM
I have damage 3 gearbox already on previous Ride and that with 40k interval!!
I think the way I drive the gearbox cannot take it hahahahahaha, that is why i choose shorter interval.Yup , the specified ATF for rexton is tough to get, even service centre also using the wrong one.
If you have not changed your ATF yet, change with the ATF Filter together. Otherwise wasting the oil. Get the better one that has snapping leg. The right ATF Oil only available at RextonHub.. should organise group purchase for ATF Oil + ATF Filter only for RextonHub member.
rx270xdi
Posted 06 October 2010 - 07:55 PM
Do you guys know how much is the spare parts shop selling the ATF for used in Rexton..? RM85/liter, and ATF for Sorento is RM68/liter.
r3xt0n
Posted 06 October 2010 - 08:35 PM
Which brand of ATF they selling for RM85/l? You not worried if it is recycle oil too?
rx270xdi
Posted 06 October 2010 - 09:09 PM
Ssangyong Brand, is actually pack by the same supplier which we get it from. hahaha recycle, how can they recycle the ATF..? adding some Air Sirup...?
r3xt0n
Posted 06 October 2010 - 10:04 PM
After Razopower experience with recycle engine oil, I don't think it's impossible to recycle ATF oil.. who know what they add to make it looks similar. I would rather stick with FUCH 3353 as specified by the spec, better confidence..
rx270xdi
Posted 07 October 2010 - 01:47 AM
TITAN ATF 3353 has been developed to satisfy highest demands to shifting comfort in modern automatic transmissions by Mercedes-Benz. TITAN ATF 3353 is formulated with selected high quality base oils in combination with a specially developed, unique additive technology. Demanding quality control ensures constant product performance.
Application
TITAN ATF 3353 is specially recommended for the latest generation of Mercedes Benz 7-speed automatic gearboxes (NAG2), as well as for all former 5-speed transmissions (NAG 1). TITAN ATF 3353 can also be used in many applications where DEXRON III-type fluids are recommended.
Advantages/Benefits
• Selected base oils with very high viscosity index give TITAN ATF 3353 excellent low temperature properties.
• remarkable fuel-efficiency potential
• very stable friction properties over the entire service time.
• TITAN ATF 3353 provides the required anti-wear and friction modifier additive systems to insure proper function during the lifetime of the gearbox.
• outstanding ageing and oxidation stability
Specifications/Approvals
• MB 236.12
FUCHS Recommendations
• BMW
• GM DEXRON III
• FORD M2C195-A
• FORD M2C202-B
• FORD M2C922-A1
• VW TL 521 62 ( G052 162 A1/A2)
• VW TL 501 60 ( G052 911 A1/A2/A6)
