Hyundai Avante X20 - Servicing
Posted 20 July 2010 - 02:27 PM
Parts Price & Labor Charge
Periodic Maintenance Service Package for Avante 2.0L
Price schedule as per 10/8/2009
Regular Service at 5,000km interval
Price subject to change without prior notice.
Labour Charge: RM70/hr.
1,000Km or (1st. Month)
Engine Oil = RM99.00 (Semi-Synthetic)
Oil Filter = RM18.00
Gasket - Oil Ring = RM2.38
Parts Cost = RM119.38
Labour: RM30.00
5,000Km or (3rd. Month)
Labour: RM30.00
10,000Km, 50,000Km, 70,000km or (6th., 30th., 42th. Month)
Labour: RM70.00
20,000Km, 100,000Km or (12th., 60th. Month)
Spark Plug = RM49.90
Air filter Element = 48.66
Auto Transmission Fluid = RM78.75
Radiator Coolant = RM27.20
Brake Fluid = RM28.60
Air Conditioner Filter = RM160.00
Parts Cost = RM512.49
Labour: RM203.00
30,000Km, 90,000Km or (18th., 54th. Month)
Labour: RM91.00
40,000Km or (24th. Month)
Auto Transmission Fluid = RM210.00
Fuel Filter = RM13.50
Parts Cost = RM657.24
Labour: RM266.00
60,000Km or (36th. Month)
Auto Transmission Fluid = Nil
Fuel Filter = Nil
Parts Cost = RM433.74
Labour: RM203.00
80,000Km or (48th. Month)
Timing Belt and Bearing = RM677.40
Parts Cost = RM1,334.64
Labour: RM455.00
15,000Km, 25,000Km, 35,000km, 45,000Km, 55,000Km, 65,000km, 75,000Km, 85,000Km, 95,000km,
or (9th., 15th., 21th., 27th., 33th., 39th., 45th., 51th., 57th. Month)
Labour: RM70.00
Note: Labour charge differs due to other parts being inspect (I), service (S), clean ©, replace ® or adjust (A).
Please refer to Hyundai Avante Service Manual.
iMotorMy...
Posted 20 July 2010 - 04:40 PM
Maintenance Service Packages and Service Intervals
B - with Shell Helix Ultra
C - with Shell Helix Ultra
D - with Shell Helix Ultra (First 3 Free Labour New Car Servicing)
E - Auto Trans oil change with Shell ATF IIIG Mineral ATF
F - Manual Trans oil change with Shell 75W-90 Manual Trans Oil
G - Flush Radiator and add Coolant
Air-Conditioner Cleaning
Computerised Wheel Alignment
Flush Brake fluid, Clutch** and Bleed System
Flush Power Steering fluid and Bleed System
Manual Car Wash
Polishing and Waxing of Vehicle
Side Slip Test - Adjustment and Centralise Steering
Tyres Rotation & Balancing
Timing belt change package
Fuel filter change
Fan belt change ( Timing chain model)
Air-con System Preventive Maintenance & Health Care Package
Air-con System Preventive Maintenance Package
1) To check air-con system condition.*
2) To flush air-con system & compressor oil replacement.
3) To vacuum & top-up 134a gas.
4) To sanitise car cabin & air-con cooling coil.
5) To replace air-con blower filter.
3) To vacuum & top up 134a gas.
Source: Hyundai Komoco, Singapore
iMotorMy...
Posted 20 July 2010 - 04:54 PM
but i wonder why the plugs, atf, coolant and brake fluid not at every 30K or 40K / 2 years interval?
Posted 20 July 2010 - 05:14 PM
These are the recommendation parts that need to be changed and serviced...
As owners, we can ignore any parts change to save money...
It's always a matter of choice...
SC won't say, if you don't change this or that, your warranty will void or something like that...
Only owners will suffer if the said parts that need service doesn't work as efficient as recommended...
My 2 cents...
iMotorMy...
Posted 20 July 2010 - 06:06 PM
Aircon fillter terlalu mahal --- potong orang .
manpower cost too high.
my Forte sudah do outside shop tak balik agent already.
Posted 20 July 2010 - 07:11 PM
The Hyundai Club Malaysia does help the members to group buy the air filters from Singapore at much lower price.
Any of you who go to Sgp can buy in bulk for many pieces and spare for few years to save mantenance cost.
My Avante is near to 70,000KM now, i never spent so much money as the above mantenance fees.
The CVVT engine is still as smooth and powerful as day 1, dun feel any degradation in performance.
I have been using the Iridium spark plug (RM150 only) since 10,000KM mileage, till now still very good, very long lasting. Maybewill only change the plugs at 90,000KM mileage.
After my Avante exceeds 100,000KM, warranty will be expired, i think will still continue to go to Kah Bintang for car service.
I feel that their charges are reasonable, even i go outside, dun think i can save much.
Also Kah Bintang is charging the oil filter at RM 14.5 only.
Posted 20 July 2010 - 09:58 PM
Does this mean KB 223 give cheaper service price and parts..?
Need to check-out later for verification...
iMotorMy...
Posted 20 July 2010 - 11:37 PM
not that sure, not only Kah Bintang Jln 223, the Kah Bintang Jln Ipoh has standard charges with other Kah Bintang SC...
I think it could be due to discounts given by this dealer...
Kah Bintang for Hyundai and Kah Motor for Honda, both are under the same parent Boon Siew, but Kah Bintang has cheaper parts and service charges than Kah Motor, not sure if it is due to Honda is more expensive than Hyundai in everything...haha
Posted 21 July 2010 - 07:50 AM
Not sure if they have standard rate across the nation, but for Kah Bintang in Sg Pinang (Penang), their labour charge is only RM10 for regular service (every 20k is major service, others are regular service).
I also find that Kah Bintang charges are reasonable, and plan to continue sending my Sonata NF to Kah Bintang for services after the warranty expires. However I'll follow the "original" schedule as determined by Hyundai Corporation, not the schedule from Kah Bintang/Sime Darby (eg 40k auto-tranny oil change, 10k service interval vs 20k auto-tranny change and 5k service interval).
Posted 08 August 2010 - 09:25 AM
Avante servicing...
Labour: RM70.00
The real thing...
Did the 10,000km service at SD Hyundai yesterday...
Engine Oil: RM99.00 (Shell-Helix Plus)
Filter: RM16.65
Labor charge: RM70.00
Sub-total: RM185.65
5% Service Tax: RM3.50
Total paid: RM189.15
Beside that...
1) Adjust head-light beam a bit higher (because seen to be too low, can't see much on speeds at night especially at highway)
2) Rotate tires (1st. time)
3) Rattling issues (after change BCM)
All and all, everything is fine, except the annoying rattling issues still was not solved...
Wishing, not to make the same mistake previously by 11th. time visiting SC to solve my previous "flickering/ blinking dashboard lights" issue...
iMotorMy...
