Tough lah to blow. Easier to kachow the shampoo in a pail, create the foam and throw by hand....muhahahahaha
Foam Gun
Posted 01 July 2010 - 07:28 AM
Posted 01 July 2010 - 05:44 PM
1. jackson (confirm)
2. anonymous (confirm)
3.
4.
Any other takers for this? Need 2 more people then can confirm get this price.
i will handle the shipping within Malaysia.. can arrange 2 oz sample of dp extreme foam (from my stock)
There is two way of using this foam gun on car.. First,let it dwell and continue with bucket wash. Second spray while you wash and prepare one bucket clean water to rinse the mitt.. Other than that, its quite useful to wash carpet (dwell with foam) and wash garage floor..
Posted 02 July 2010 - 12:12 AM
3. daws (confirm) pay first or later tq?
4.
Posted 02 July 2010 - 12:24 AM
i believe it is COD. unless mankarat says otherwise
one more spot left...
3. daws (confirm)
4.
Posted 02 July 2010 - 01:06 PM
3. daws (confirm)
4. behcw (confirm)
Ok now all fully taken.. Fuh! thanks guys.. As for the payment, KV guys can cod to me when i come down to KL.. and for outside KL i will ask the money before i send the item. I'll back from ship on 30 July.. I beleive by that time the foam gun should arrive at my home already.. I will update any news regarding this matter.
Posted 02 July 2010 - 01:53 PM
3. daws (confirm)
4. behcw (confirm)
Good news for bro. jackson......
Posted 02 July 2010 - 11:33 PM
3. daws (confirm)
4. behcw (confirm)
looking forward to it.
Posted 03 July 2010 - 11:03 AM
And I hope to get my brush also........
Posted 05 July 2010 - 12:14 PM
But to put it simply, from what I have gathered thru web searches, other detailing forums, usage practicality:
Foam Gun:
+ side;
Easy to setup. Almost no setup at all.
You should have your garden hose ready at all time. Just need to cucuk this foam gun to the hose, add shampoo in the container (some add a bit of water too, depends). then you're all set.
Totally new meaning to plug-n-play.
- side;
foam not as frothy as foam lance.
foam will not cling or dwell. stronger shampoo or foam shampoo might help but you run the risk of stripping whatever you had put on.
Foam Lance/Cannon:
+ side;
foam very frothy.
foam dwells/clings nicely.
- side;
A bit tedious for a home-user to setup. what more an apartment dweller to use.
You need a pressure washer/power washer (PW). Then the foam cannon to be fitted to the PW bayonet. Then you need a long power cable and long PW hose for you to go around the car spraying foam.
And since using a PW washer, tends to give lots of overspray. You may end up with foam all over your porch or compound.
Summary:
For a home-detailer or apartment-detailer, foam gun is the one. Makes washing easier, faster to complete. No need for 2 bucket wash all the time.
For a serious or commercial user, foam cannon is the one. If it wasnt for the setup time, the overspray, mess up the whole porch, this would be ideal for home/apartment casual user.
Hope this helps ppl make decision to get/not to get, and which one to get.
Yup ..Foan Gun more practical for home detailer..
Apart from this, u can used this to foam the car porch floor as well ..anything. Easy setup is the key.
Anything above 40 psi water pressure will do. If low on pressure, u can let the pressure build up as long as u dun keep pressing the hose sprayer. basically press n off.
Of course, the foam lance will generate for foam but troublesome.
3. daws (confirm)
4. behcw (confirm)
good price man~..
neway, I am bringing soon.
www.duragloss.com.my
Posted 05 July 2010 - 01:34 PM
