aka contamination. Recond cars you'll never know lol. Not really sludge la, as in... freakin dirty
Gear Change Jerking
Posted 02 September 2010 - 01:29 PM
Posted 02 September 2010 - 02:17 PM
Recond or 2nd hand cars, don't know their past records. Normally when purchase one, I do all the fluid change.
Engine oil, Gear Oil or ATF, Brake fluid and clutch too if hydraulic, radiator coolant....oil & petrol filter too....
Posted 27 December 2010 - 02:38 PM
Please advice if send to repair gear box. can it solve?
Hi there Getzer, mine is 1.3 2003. Just to share. I am a frequent road user to JB so I service my car on time, maintain 40K GB oil change with filter. My case was the GB fails at 185 000km. But that was because some circumstances where a Negro in a Naza Ria to blame.
The time it fails, I was cruising at about 80kmh where suddenly the gear drops to 3rd, cannot go up or down. Send to JKS in Balakong for refurb my GB. The GB works well when cold, but start to jerk when going from 3rd to intermediate gear and when stagnant in 'D'.
Some say whenever GB is being operated(overhauled) , the perfomance will never be as same as new one. I am not really sure wit this quote but if you happen to be in KL, you may try visit Sun Eng Hup, where they will test the GB before installation.
Just sharing.
Posted 27 December 2010 - 04:46 PM
Just sharing.
Seen my mechanic overhaul GB before and no problem. Major problems one, can get recon unit rather then overhaul.....
Posted 12 January 2011 - 11:00 PM
What type of car ur mech refurb? toyota? actually mine is consider recond but i insist they use the existing GB to recond it.
Posted 12 January 2011 - 11:49 PM
Some mechanic recommend not to flush if you have not totally flush before because that might affect the pressure and created unintended issues. Most importantly, is to clean the magnet and change the ATF Filter. Also make sure the right ATF according to the spec is used.
Posted 12 January 2011 - 11:51 PM
Right, not many has the real experience and knowledge to rebuild one. Many workshops only half bail water to tipu makan.
Posted 13 January 2011 - 10:15 AM
He repairs all sorts of cars. For GB, he will repair or try to repair. If major problem, normally they buy recon unit to replace if okay with owner. Old GB not sure recon company will take or not.
Posted 13 January 2011 - 10:17 AM
That is the problem. Owner should have maintain the GB with regular maintenance, then flushing is not a problem.
If GB already develop problem or longtime did not change atf, then no advisable to flush.
Posted 13 January 2011 - 10:18 AM
ha! ha! yup some mechanic half pail water also try to cari/tipu makan.....
