Car Tire Pressure Gauge
Posted 24 February 2010 - 11:18 AM
I did read online saying the 'stick' type of hand held gauge are not reliable and should go for the dial type. But I have so far nothing much to complain about the 'stick' type PCL that I been using for years.
Posted 24 February 2010 - 12:32 PM
One pump actually deflated my tyres so you can imagine how well they are maintained.
lelong.com.my/friendlystore
Posted 24 February 2010 - 10:26 PM
Whether dial type or stick type of gauge depends on the brand also and whether their calibration is correct.
I had a dial type before and at the end there was a screw sort of dial for you to tune the pressure.
I went and match it against my friend's tyre shop Michelin one.....
You kept the pump thing on even though it was releasing air??
Posted 25 February 2010 - 01:22 PM
Of course not, I drove to a different pump, with a slightly deflated tyres.
Posted 25 February 2010 - 02:00 PM
ha! ha! yaloh, some station pumps are that bad. The Esso in Shah Alam, Digital one not working, the dial one really out.
I tried once, dial 34psi, but found it bumpy. Check with gauge shows 40+ psi......
Posted 25 February 2010 - 11:14 PM
Posted 27 February 2010 - 08:16 PM
But for my tyre size of 215/45/R17, using the bicycle takes too long.....tried before....ha! ha!
Yup, that is one way to verify and compare your gauge accuracy and then add accordingly if the gauge cannot be adjusted.
Yes, for outstation add 2psi more.....
Posted 27 February 2010 - 10:46 PM
I bought this bicycle pump with a cylinder at the base of the pump (don't know what is the name). The cylinder gets pressurize as I pumped. Generally between 6 to 12 pumps, depend on the tire size, equal 1psi. It is not so bad have been doing that for many years beats going to petrol station and the pump is out of order.
Posted 28 February 2010 - 12:54 PM
Including getting some exercise to go with it.......
Posted 28 February 2010 - 03:31 PM
But recently my dad moved the air compressor to a inconvenient place, so I started to use petrol station air pumps again. Usually pump 36PSI, go home, cold night release to correct pressure.
