Microclean Diesel Filter
Posted 21 January 2010 - 05:57 PM
Any using Microclean Diesel fuel filter in your vehicle ? Truck, contructor, tractor, Else.........
Normal filter just about 5 mikron but with microclean filter 1 micro,.......
Regard
Jack
Posted 24 January 2010 - 06:44 PM
I juse done my install Micro clean filter on my Nissan Navara, seems respond increase and lower engine noise.
Exactly can filter the diesel fuel become clear........it help filter sulphur due to malaysia diesel fuel contain alot sulphur.
I will post some pic here...I bough RM 900 with install..Really worth.. .especially for nowaday sensitive common rail engine. must use batter diesel fuel filter and must have a good water seperation.
Posted 23 March 2010 - 08:41 AM
so soon i would show the actual used 5000KM Microclean filter, compare new...
Looking ? please call 016822 two seven one four.
Regard,
Jack
Posted 19 April 2010 - 07:48 PM
The result can look from here new and after run 5000km and the element become dark, it trap malaysia fuel diesel fuel which still contain alot sulphur and not good fuel diesel fuel system.
result, now less smoke, engine sound slightly soft, power increase by little......
there is a pic inside...
Looking microclean filter assembly ?. please call to 016822 two seven one four
Posted 19 April 2010 - 07:49 PM
www.microclean-filter.blogspot.com
MICROCLEAN ENVIRONMENTALLY FRIENDLY DIESEL FILTER
Main Feature :
Remove Particle & water contamination
Reduce Black smoke Emission
Longer Fuel Injector Lifespan
Extend Engine Life
Maximise Fuel Combustion
More Acceleration power and smooth power
Reduce Engine Maintenance Cost
Replace filter element every 25000KM only
Micron Rate : 1 Micron...
Filter out sulphur in diesel fuel to engine
THE SOLUTION TO YOUR DIESEL ENGINE
The Product That Guarantees Performance
We do carry 2 model of fuel filter which is
AL 120, Dimension = 150MM X 190MM
AL 280, Dimension = 150MM X 375MM
Comparison between Genuine Manufacturer Fuel filter and Microclean Fuel filter
Genuine Manufacturer Fuel filter element using Paper, rate of mikron just of 30
Paper element can easily soak with water and let drop of water to fuel pump
Genuine fuel filter come with water seperator but it's to late to tell u when the water is reach full thru this drops of water mix with diesel fuel to fuel pump and injector.
Microclean Fuel filter Element using celaulose fiber, rate of mikron 1. Celaulose fiber won't soak with water so this element will really seperate water to below(water seperator place) and drops of water can't flow to fuel pump. This Microclean Diesel fuel filter able to filter out sulphur contain in diesel thru this minimize fuel pump and fuel injector to service or do replacement and reduce cost to repair as well.
This Product Tested And Proven By Sirim as well Company feedback
This product Tested and Proven.
Posted 25 October 2010 - 09:47 AM
Posted 30 October 2010 - 11:52 PM
Patrol Not needed 1 Micron rate filter....pointless if use on patrol.....ofcoz super clean...but still no function.If diesel, Yes function good and purposely....
Posted 23 November 2010 - 12:04 AM
Good water seperation is a must. I deleted the pictures,it wont come out.
thanks.
Posted 10 July 2012 - 06:44 PM
Hello jack, where can I buy these micro clean filter for my Navara?
