Alza Vs Avanza
cucuk
Posted 15 December 2009 - 11:12 AM
cucuk
  • 6,139 posts
QUOTE (pciericagp @ Dec 14 2009, 02:19 AM) <{POST_SNAPBACK}>
The choices is yours. I can just said toyota avanza and perodua alza was same quality as both are manufactured in the same plant and production line. Confirm! Sources was from people working inside perodua. Perodua already got facility to built K3-VE and 3SZ-VE engine, gearbox only source from japan. Even avanza was 90% local content since facelifted.
Please don't compare MyVi quality with this Alza cause different production line and robotics system. I got confident on the car. Shall be average as good as kelisa with minimal failure rate. Please check on the transmission, is was direct 4-speed automatic transmission without OD, different from Avanza that using OverDrive. It provide better fuel efficiency.
Is just a bit desperate cause even toyota avanza also doesn't equipped with ECT or Super ECT auto transmission.
i tot that OD is just a switch, u can also disable the OD by engaging D3 in the alza, that is also just another switch to tell the GB what not to do
abim
Posted 15 December 2009 - 12:39 PM
abim
  • 1,968 posts
QUOTE (cucuk @ Dec 15 2009, 11:12 AM) <{POST_SNAPBACK}>
Agreed with u cucuk...
ABIM
tiger1986
Posted 21 December 2009 - 12:32 AM
tiger1986
  • 192 posts
I had a chance to drive Avanza 1.5 auto lately (Wasn't test driving, but driving in and out of Singapore with more than 200km covered). Not yet tried Alza.
I felt lack of power. I had to almost redline it all the time except during cruising. No need to mention about stability. The suspension is too soft and bouncy. Azla got these weaknesses? If I'm not wrong Alza is a lighter car.
pciericagp
Posted 02 January 2010 - 03:52 AM
pciericagp
  • 533 posts
QUOTE (tiger1986 @ Dec 21 2009, 12:32 AM) <{POST_SNAPBACK}>
Alza don't had this weekness, is FF car with monocoque body. It much more driving like sedan, bit heavier than avanza. Suspension was fairly good, firm and you won't felt bouncing like avanza.
