Current Ulysse
tazztham
, May 05 2007 11:22 PM, 17 replies to this topic
Posted 16 June 2007 - 07:42 PM
hi zulfa,
Its a good news to us isn't it ?
Juz let me know its the spring is available.
My mech over here ever did it to a fiat tempra and it works well.
Will contact tony if its available oredi.
2. The water from the radiator tank of mine always overflow thru the cap.
I saw an overflow tube or hole juz at the side n below the water(or
rather coolant)cap from 806. Mine dun hv.
aGip Ulysse
aGip Ulysse
Posted 16 June 2007 - 10:59 PM
hi again,
the overflow rubber hose is DIY, just go to bike shop or aquarium shop to
buy those rubber hoses and fix to the overflow pipe.in bike shop, just say
carburettor hose. because the target for the overflow pipe seems to be the
stepper motor, just below. to prevent that, just buy about a fathom and fix
to the pipe.
the fiat mostly used hydraulic clutch. unlike our mpv, it uses cable and
since this cable runs through the exhaust piping, the grease/lubricant
inside have tendency to dry up. tony told me that he will enquire about the
price.hope to hear from him soon.all our woes will end once the clutch is
light like kancil.
zulfa
to the pipe.
light like kancil.
zulfa
Posted 17 June 2007 - 02:07 AM
i dun really sure where to ,create a hole at the water tank on top. mind
show me of yours zulfa. i mean a pic of yrs.
there sgould be an overflow or water isn't it ? or just hot air vapour
out from that tank.
My ulysse uses clutch cable. Juz replace a new one recently. A bit light
but still waiting for kancil touch.
out from that tank.
Posted 17 June 2007 - 02:08 PM
agip,
u can see a small pipe extending about 1 inch below the radiator expansion
tank cap. that is the overflow pipe. see also the direction of flow,
directly to the stepper motor/throttle body area. not very good since most
rubber seals for those electrical connections get lousy after several years.
zulfa
zulfa
Posted 17 June 2007 - 06:09 PM
The problem is there is no such small pipe in petrol ulysse . There is in
1.9 TD. Thinking of making that kind of overflow pipe. The cap is in
screw type .
Any idea of making that pipe ?
screw type .
Posted 18 June 2007 - 11:01 AM
hmmm mystery jugak.
i think all the expansion tank have that small pipe. well, check with it.
back to u later.very short pipe one.
zulfa
zulfa
Posted 18 June 2007 - 01:12 PM
as i told. the small n short pipe didnt exist in mine.
seen d pipe in others.
So now whenever the water flows ....it flows thru the cap.
how tight i close or screw the cap it the water still flows.
sayang la nak tebuk2 lubang utk piping tu.
Posted 22 June 2007 - 10:50 PM
Zulfa..thanks for the info. update me if the spring is available.
Do you have any idea know how much it cost?
