chekai, tolongggg
Posted 17 July 2003 - 08:43 PM
to start after the injection light is off, the keycode light won't go off. i
had to switch of and retry to get rid of the keycode. scares the living
daylight out of me la. pelik la.
and another thing, when i slam on my brake, the lights, cabin,
dashboard, meter, even the headlight seem to be affected as well
and there is a clicking sound. everytime i step on the brake, you know
why?
and lastly, i have no idea why i felt such sudden power lost, since i
just overhauled the engine few months back.
the thing is, i have no time at all la to send the car for check ups. i am
always at the office. when to go to your house also i can't tell.
Posted 18 July 2003 - 09:25 AM
Since U just overhauled yr car...probably some of the wiring & earthing
not properly tightened. Regarding code & headlight seems affected,..need
to check your:-
1. Battery voltage & what cause the voltage drop.
2. to check wiring hardness, especially at alternator & other connections
at engine compartment & at the dashboard as well.
3. Need to check the earthing, at engine compartment & at the dashboard
too...to check if any voltage drop of the earthing system.
Sudden power lost: Initial checking need to be done: (banyak lagi mahu
check..tapi check ini dulu maa!)
1. The timing belt marking at crankshaft & camshaft...should be aligned
2. Need to check the belt, it is not too taut or to loose
3. Need to check the gap of the Rpm & TDC sensor whether within
specification.
4. the exhaust system.
Aku ni agak2 ajer Sub....
Posted 18 July 2003 - 10:25 AM
malam je. entah bila entah ni?
and about the power lost, my exhaust system meman gdah kapoot dah.
especailly my header and the backbox.
Posted 18 July 2003 - 10:48 AM
sending my car to Torino for repairs..later found out..the battery
connection is not tighten...
Posted 18 July 2003 - 11:12 AM
Posted 18 July 2003 - 03:25 PM
I had a similar problem, about the electrical and lightings. They found
out that the spotlight wiring is cut. So, touching the body that caused
the elctrical problems.
Thanks,
Posted 18 July 2003 - 07:20 PM
i switch off and re switching on. and i found out last nite that sometime
it clucks and light blinks at the same time while i slam on the brake.
but i gatal kacau the fuse box underneath the steering wheel, and
everything was ok? even the meter panel light was out until i kacau the
fuse box. ada connection dengan brake light ke ni? syed, thanks man.
Posted 19 July 2003 - 04:02 AM
Jedi Sub,
Kat sini ko ah.Kitorang tgh belasah kau kat Car Mod.
What happen to your car la? After installed that turboPlus engine,is this
the result?hehehe guess next TT kena tapau lagi la ngan stoner's setan b61a
>why?
aku baca 2 kali baru aku perasan ayat kau.aku ingatkan tiap kali ko slam
brake, semua lampu termasuk cabin light menyala.ada bunian duduk dalam
kereta ko kot hehehehehe
wei i need u to teach me more about that boast meter la.that 3 in 1 evo 3
meter ( water, boast and volt meter ) can be fitted on my EG rite?
feedback pls!
Posted 19 July 2003 - 02:26 PM
kereta aku standard dan semakin tak ada power, itu le yang aku
risau ni. and about that boost meter or vacuum, wait la, let me master
it too then i'd teach you. and yup, you can put those gauges into your
eg8, no worries.
Posted 19 July 2003 - 03:02 PM
busy kunun.masuk AW tak busy?
aku dah tgk si eegee punya kereta oto masuk vacumm, thats why i wanna ask
u.how la
