What Is The Most Basic Modification?
Posted 03 October 2009 - 12:54 PM
I think the principle of modification is to increase horses. for entry level of modification, what do you suggest for moding a V6 engine? change plug? cable? K&N filter?......
Happy moon festival...
Posted 03 October 2009 - 05:01 PM
what ive done to my ride do increase perfomance a bit..really noticeable at low to midend..but top end..still d same..(very fast goin up to 180kmh compare to b4 modding)..
1.k&n drop in air filter..
2.cyclone air turbulance kinda thing in d filter box(read lot of bad thing bout this product,but been 3 years now..and d result is good )accelerate more faster..
3.hotbits full exhaust system(from header to muffler wif bullet in d middle,drive an automatic so uses s-flow type)
4.volker iridium sparkies wif pro rallyie cables..(not any much difference..but fc improves a bit)
ive done d modification bit by bit to test d improvement invidually..
now im looking forward to
1.pnp or maybe polish only wifout ported.
2.lcp (still researching bcause heard some bad thing about harmonic damping after change to lcp)
3.bigger injector
4.bigger fuel pump?
5.that fuel pressure thingy..
6.ecu remap?piggyback oe reflash..(guess something is holding up my car from exceed 180kmh..maybe its d ecu?)
fast and reliable wont b cheap
reliable and cheap wont be fast
Posted 03 October 2009 - 05:42 PM
3.bigger injector
4.bigger fuel pump?
Regarding about the LCP , try Methology LCP which is dampened, tho' the price is more than double of those in the market but the quality is there and rest assured .
Pick up seemed to be better but don't expect any increase of HP like some people said .
Regarding bigger fuel pump & injector , no much of a point unless the performance parts ( PnP , Performance cam , ECU .....ect ) have been modded / upgraded into your engine first . Just my 2 cents worth .
Posted 04 October 2009 - 11:28 PM
yup..ure right!! pro rallye cables bacame soft when hot..boleh d tekan2..and d colour of d cable fades too..
i bought mine for rm200..damn it..been using it for 2 years now..i bought it because speedworks dont hv any cables to fit in wif volker iridium..so they suggest me on pro rallyie..they say cheaper than NGK N NOLOGY which is rm300++..im attracted to that grounding cables that comes wiff pro rallye
those performance upgrade i mention above did some job on increasing my standard 92bhp to 97bhp..and d most important thing i "felt" d power when driving..
ps-upgrade stuff at one shop but dynoed at d other shop..(just trying to get honest result)
Posted 05 October 2009 - 12:12 AM
Just for info : NGK cable cost around RM500++ & Nology Hotwires cost around RM700-RM750 . The ProRallye followed the Nology Hotwires's concept .Just that the material they used are of poorer quality if compared with Hotwires . Sorry ,no offense meant . Just trying to get things straight out .
I do believe that the Hotbits exhaust system & the volker iridium sparkies do some little wonders but the ProRallye cables I doubt . Even if it does , also it's not much noticed . Try putting back your old cables for a spin if you doubt what I said . My friend just did that to realise it . His ride is modded similiar to yours except that his exhaust is from Apexi & sparkies from Nology Silver .
Posted 05 October 2009 - 01:55 AM
nahh..non taken..actually i appriciate ur feedback..no wonder lah pro rallye looks similar to nology..kinda imitation or 2nd class quality..sumwer in 2007 i was quoted rm350 for NGK and rm400++ for nology..dunno lah fake one or not..but at a famous performance upgrade wkshop here..the price is increasing nowadays eh?
i wont go so far as rm500 or rm750 for a sparkies on my old ride..can get myself 60k km mileage recond auto gb oredy at that price..
my old cable ive thrown oredy..after 12 years using it..hehehe
the only problem wif my ride is why la cant exceed 180kmh mark or cant go pass 6krpm? when idle i can rev it till 8k..? on highways..i tekan d pedal 80% =180kmh , tekan 90%=180kmh , pedal to d metal=still 180kmh.. what kinda speed cut is this?
very d sakit hati when savvy and saga blm following at d back closely on d highways at 160kmh...(the only thing i noticed i can only outrunned them if im steppin hard from 160 to 180 ..torque powerrrrr)
savvy 1.2 n saga blm seems lack of torque..but when im doin 170kmh comfortably ..look at d rear mirror they are still there!!
Posted 05 October 2009 - 11:48 AM
i gave away my prorallye as it made more static noise than so called power also did dyno tests and tiada apa apa naik pun except my beban bank naik! hahaha
Bookmark this now - www.myforteclub.com
Posted 05 October 2009 - 11:51 AM
If not mistaken , your's ride is a Civic EG/SR4 right ? If possible try to scout for a Hondata ECU & a good tuner to fine tune it .Guess that will do to push it to the limit , another 10% - 15% additional HP. Most important is the tuner ,must be able to find a expert if not later on wrongly/mismatch tuned engine blown . Happpened to a friend of my friend before .
Posted 05 October 2009 - 05:05 PM
but hondata is transerable right? good investment if im swapping engine..
need for speed is everywer in my vein now... at least 200kmh will b enuff
Posted 05 October 2009 - 05:38 PM
200km/h enough ah????
don't believe...
coz my bike was 140 before this...even now speedo reading out of scale still not enough....gues lust for speed never gone....even f1 might be not fast enough after we getting used to it...
(NFS Underground)
