So in that case can we use one only, instead of both, so we can save on one mah.......
added some machine instruction for 501Maybe I will list down some basic steps which will be easier rather than keep emailing... Bros here can share with their own or new technique as well.
501->601->601->105/trackclaw
Step1 Paint cleaning with 101/501 AIO Damp the MF Applicator Pad with filter water. Pour a 5-10-cent size amount of product to MF Applicator Pad which is good for 2x2 feet working area, try to use Straight Line method and avoid circular motion to reduce marring for all products. A thin layer, hazy and cloudy effect is good enough. Use little force to apply especially for stubborn stain. Mist some filter/distilled water again if the MF applicator pad has dry up.
You can do another round of polish with 101/501 if you noticed the paint is still dirty (especially white) because 101/501 will improve clarity of your paint. After that, proceed to next area without buffing off because you can complete the whole car to save your time. The 101/501 will turned haze after about 5-10 mins and it is ready to buff off, you can even leave it on for another 1-2 hours before buffing off.YOU ARE DONE NOW.
By Machine: Bosch ROB with Polishing pad (LC 5.25ā€¯ White). Mist and Prime the pad with filter/distilled water or DG521 Detailer Spray. Put about 2-3 small drops for a 2x2 feet working area. Set to Speed 3 and you are ready to go. For RB users, set to 1000-1100rpm. Mist some filter/distilled water again if the pad has dry up.
Step 2: 601 Paint Bonding Agent. This is an OPTIONAL step that you can do if you have the time. Pour a 10-cent size amount of 601 to a MF Applicator Pad and do a quick wipe on those panels that you want to detail in Step 3 . 601 PBA are transparent and you might not see the hazy or cloudy effect.
The 10-cent size amount of 601 can work on an estimated 2 feet x 2 feet panel. You just need to wipe and glides a thin layer of 601 over to paint surface without much pressure. NO need to buff off
STEP 3: 105 TPP/Trackclaw Sealant Protection. Use 5-10-cent size amount of product is good for 2 feet x 2 feet panel. Apply onto panel with thin layer, cloudy and hazy effect is good enough. Allow time to haze for about 10 mins and you can start buffing-off with MF Cloth. You can also apply to the whole car before buffing-off to save more time. If you prefer to apply 2 layers of 105/TC, please allow 4 hours curing time before the next layer. With 2 layers, you will gain more protection and deeper in color.
By Machine: Bosch ROB with Finishing pad (LC 5.25ā€¯ black or blue). Mist and Prime the pad with filter/distilled water or DG951 Aquawax. Put about 2-3 small drops for a 2x2 feet working area. Set to Speed 1 and you are ready to go
www.duragloss.com.my
