Engine Oil
Posted 02 September 2009 - 12:29 PM
Posted 04 September 2009 - 09:16 AM
I've been using 5w-40 fully synthetic for over 50k km with no problems. OCI is 10k km.
xW-30 is too thin for normal campro but recommended for cps.
Posted 19 November 2010 - 10:18 PM
Bro, U familiar with Engine Oil? Can u Brief more in this topic? i was struggle what type of Engine oil to be use..
All Forumers..... Please place your comment ........Thanks.
Posted 02 December 2010 - 11:25 AM
i'm no expert in engine oil.. if you need more help on this topic, please go to the Petrol and Oil section in this forum
personally i have been using Q8 Excel Fully Synthetic 5w-40 for the persona since the mileage is 10k km.. now engine is 90k km and i change the oil every 10k intervals. no probs yet in fact the engine still feels like new i will keep continue using this oil for the next few years.
You can use either for mineral, semi-syn or fully-syn as long as the grade is xw-40 (x could be any number, eg. 5w or 10w).
Posted 03 December 2010 - 03:43 PM
A 5W-40 Fully Synthetic from a reliable source, changed no later than every 15,000 Km is good.
Posted 28 January 2011 - 03:48 PM
can anyone clarify back on this?
thanx
Posted 28 January 2011 - 07:31 PM
thanx
I would ask them where the extra 'engine noise' would come from exactly? Valve train
or piston-ring slap, crank bearings or some other component?
I can see the logic in using slightly thicker oil when the engine is older/has done much
higher mileage, but using good quality synthetic oil from the start will postpone the day
that's required anyway.
Posted 28 January 2011 - 08:17 PM
svc interval: 10k km
brand: any branded ones will do..
Posted 28 January 2011 - 10:09 PM
thanx
i've been using fully synthetic on my 4 year old car, mileage is 100k now, still ok, no noise whatsoever. my oil change interval is between 8-10k. But recently i have upgraded to slightly thicker grade 40.
Posted 29 January 2011 - 10:44 AM
btw not to forget the following:
- radiator coolant "use toyota coolant": every service interval flush/replace
- ATF replace every 20k km. flush every 40k km
