Brake Disc Worn To The Limit
Posted 02 August 2009 - 11:24 PM
on the jobsheet, and the service guy as well, told me that my brake disc is almost finish
is there such condition? disc kong at 100k km?
i tot the disc can last sooo much longer
n they quote RM500++ for the disc
Posted 03 August 2009 - 08:25 AM
Hi ezairi,
I changed my disc brake around 110k km where I got them changed at bluebox glenmarie about 2-3 weeks ago. They also told me that the disc brake almost finish. All the 4 disc brakes and brake pads were replaced and it cost me about RM1800 :-(
Posted 03 August 2009 - 09:35 AM
ezairi,
RM 500 per disc only?
Posted 03 August 2009 - 10:50 AM
To replace your brake disc after 100K km is quite a good thing to do. And not weird or fishy.
I had mine replaced (the front disc set) somewhere at around that mileage. Had to change the brake pads too. Using a used brake pads with a brand new disc is not the best / smartest thing you can do. But i'm not sure if its wrong or whatnot.
The reason for the change? The disc thickness has exceed the minimum threshold and all sort of irrirating things have been happening.
The rule of when to change a brake disc is quite straight forward.
Its all depend on the original thickness of the disc.
Let say the original thickness when new is 20mm.
When the thickness go below 18mm (i.e. 17.99mm and below) its time to change the disc in order to maintain the proper braking operation and performance.
basically, 2mm lost in thickness mean the disc is worn (1mm per side) and need to be changed.
If your new disc thickness is 22mm, the minimum thickness for the disc is 20mm.
This is Peugeot recommendation, at least applicable to the 206.
To measure your disc thickness DIY, you can use an outside caliper or (angkup luar in Malay). Better still if you have a Vernier caliper.
refer here is see a picture of them:
http://en.wikipedia.org/wiki/Caliper
Good luck finding it for yourself!
Note: I'm not so sure if the 2mm rules applied to the rear disc too. Hope anyone can confirm this.
Posted 03 August 2009 - 10:55 AM
front disc 619.20
front brake pad 331.70
2 brake disc (rear) 402.70
Brake pad (rear) 215.30
labour for front brake 81.00
labour for rear brake 81.00
The total cost is 1739.. burn a hole in my wallet
Posted 03 August 2009 - 11:24 AM
front disc 619.20
Now wonder the bill is high.............. Rear brake disc?...... is it Bestari that your are using? cos bestari should be using Drum brake at the rear........
Posted 03 August 2009 - 12:28 PM
Mine is the CBU unit, not the 206 Bestari.
Posted 03 August 2009 - 07:55 PM
Brake pads RM130 - Peugeot Singapore
Brake discs RM 260 - Peugeot Singapore
Labour charge - free, because I change myself and is easy to do.
See how i did it - http://tysontalenta....brake-pads.html
Naza KL quoted me over RM700 for the whole thing... needless to say I didn't bother buying from them!
Posted 04 August 2009 - 10:21 AM
Wow!! Good one! - the pics and step-by-step instruction!
Posted 04 August 2009 - 01:57 PM
Nice info but i guess not all is kaki DIY like yourself... so.. still had to pay more for it hehe
