Cloning Of Key
Posted 13 June 2009 - 04:57 PM
Posted 14 June 2009 - 04:33 PM
The keys can't be cloned, you can only buy a new casing for the remote but if you want another key you need to order from Peugeot. Its priced about RM400++ including shipping. I believe you can order a limited set only.
Posted 14 June 2009 - 08:46 PM
BEH lost his and cost him more than RM 800 to get it replaced...
Posted 15 June 2009 - 08:10 AM
Alan, if you can get one - i think probably you can bring to Pug SC to ask them to program for you. If i'm not wrong, the remote should be a generic transmitter type for all 308 with individual ID, whereby they just program the ECU to recognise ur remote id to allow it to run the car.
The casing alone cost almost RM300... for the 206 controller. Replacement for 206 is RM5xx .. So i think the RM400 is just for the casing.
Posted 15 June 2009 - 10:00 AM
Then I was misquoted when I asked how much it would cost from BB Glen. RM800 is pretty steep for a spare, but the chip embedded in the key is unique hence probably the high cost. I dropped mine a couple of times so eventually I will need to replace as well.
Posted 15 June 2009 - 12:43 PM
Posted 20 June 2009 - 03:06 PM
Guys,
I found out how to clone the remote key.
The 308 can program up to 2 remotes to use and 3 spare keys. So, the capability of the system is maximum of 5 keys.
As for us, we want to have at least 2 remotes, and this can be done if you have another remote with the properly copied key from the locksmith.
However, there is a way to clone the immobilizer and the central locking too.
The best part is, I manage to buy a brand new remote at only RM 520.00, instead of buying from Nasim at RM 808.00. Not just the casing, but the entire remote.
I should receive the remote in about 2-3 weeks. I will cut the key and reprogram the remote myself. It should work. However, if it does work, does anyone of you want to have a spare remote? Maybe if we buy in bulk, it will be cheaper.
However, let me be the first the test dummy on this... It would always be great to have a spare remote.
Posted 20 June 2009 - 03:28 PM
You can program the remote key by yourself to unlock and lock the central locking
But you need to send to SC to learn the immobiliser to start the vehicle, this is when the immobilliser code is required.
The remote key and the immobilliser are 2 different things
Posted 20 June 2009 - 04:18 PM
Noted... will try it and go back to SC to get it done... tqvm for the info..
Posted 20 June 2009 - 04:29 PM
Bro, count me in leh...
