Toyota Service
Posted 29 May 2009 - 09:36 AM
i had found out that the TGMO engine oil sold by UMWT can be used for either 10,000km or 6 months not only for the full synthetic or semi synthetic BUT also for the mineral based oil.
this is official but unfortunately not many SvA knew about it.
this is proving that Toyota maintenance is very low. No any other franchise dealer are willing to do so when involving mineral based oil.
Posted 29 May 2009 - 10:18 AM
Thanks alldisc. Cheers to Toyota technology.
Posted 29 May 2009 - 10:23 AM
all disc,
If for me, i would not risk my self using mineral oil & run till 10k km so much.. If full syn oil 10k km can la.. A friend of mine use semi syn oil 4 his vios & run till 10k km, he told me it was sluggish & high FC at the end(probably 8k-10k km). This is maybe due 2 the oil is worn out at 7k km. So again, no way mineral can go 10k km. Just my 2cents:)
Posted 29 May 2009 - 12:45 PM
Posted 29 May 2009 - 05:03 PM
as junyih6699 and alatribe has described - using mineral based oil for 10,000km doesnt feel as nice as full synthetic and they are correct. full synthetic are much more superior in terms of anti oxidasation and other agents contained to give that extra protection and hence the more money needed to spent.
again this topic is meant to let all toyota owners here (especially during warranty) that they can do so and in case they refuse and would like to stick to traditional method they can choose to do so.
Posted 11 June 2009 - 02:22 PM
service life : 40,000km
fluid colour : dark red
mixture prescriptions : 50:50
Toyota Super Long Life Coolant
service life : 160,000km (first change), 80,000km subsequently
fluid colour : pinkish red
mixture prescriptions : pre-mixed type.
comparisons
Proton - every 40,000km
Kia - every 40,000km
Posted 11 June 2009 - 02:44 PM
old model NCP42
1. Engine Oil RM61.90 (mineral based)
2. Oil Filter RM29.20
3. Drain Plug Gasket RM1.70
4. Automatic transmission Fluid RM157.20 (flush)
5. Power Steering Fluid RM21.90
6. Air Filter RM 65.00
7. Spark plug RM32.40
8. Coolant RM47.80 (2 litres)
9. Brake Fluid RM29.80 (1 litre)
TOTAL + labour and tax = RM644.90
new model NCP93
4. Automatic transmission Fluid - (change at 80,000km)
5. Power Steering Fluid - Electric Power Steering, no fluid
8. Coolant (change at 160,000km)
TOTAL + labour and tax = RM349.00
see any difference?? cost of servicing has been cut by half! way ahead of competitors.
Posted 12 June 2009 - 12:07 PM
Nevertheless the labour + tax = RM129 (from the list), is high in term of work done. Chg oil, plugs, filter, brake fluid is simple jobs, labour cost should be much lower even by TYT standard.
Posted 12 June 2009 - 02:07 PM
Posted 12 June 2009 - 07:30 PM
1 - Drain plug gasket - RM1.70
2 - Oil Filter - RM29.20
3 - Toyota Motor Oil - RM56.61
How come the Toyota Motor Oil is not as told (Engine Oil RM61.90 (mineral based)). Or maybe he not change oil for me? Only Top up? Any idea?
Checking into the compare between NCP42 and NCP93, understood the NCP93 does not have power steering pump and so we can save the replacement of fluid. Regarding to the replacement of Toyota Super Long Life Coolant, it is awesome Only replace at 160,000km. This is very good but what could be the charges from SC if we (NCP93) are going to replace this Toyota Super Long Life Coolant? If it is too expensive, then can we use the Toyota Long Life Coolant as replacement? How about those NCP42 can upgrade to use this Super LLC? Any idea?
Regarding to the ATF, NCP93 only need to change at 80,000km, so it must be FLUSH, but not drain and refill? Or only top up? Any difference between the GB of NCP42 and NCP93, to make the ATF replacement interval different from each other?
It looks like the 40,000km service is a lot of save for NCP93 (RM349 only) due to the PS fluid, ATF and Super LLC. However what about
1 - the repair or replacement cost of electrical power steering? Or the service cost?
2 - the replacement cost of FLUSHING during 80,000km
3 - the replacement cost of Super LLC?
