Lightened Crank Pulley for Better Pick-up?
Posted 09 April 2009 - 02:47 PM
Posted 09 April 2009 - 03:15 PM
Bro.
I think this have been posted many times already.
Maybe you could do a search into the past postings for some results.......
If not, wait and see whether the brothers here would want to go through this issue again....
rdgs,
Posted 09 April 2009 - 11:16 PM
better pickup yes..but no hp gain.
Posted 10 April 2009 - 12:37 AM
bro drex....someone looking for your's specialty...............
My name is michaelJenn.
I'm the grave digger....
Posted 10 April 2009 - 08:01 AM
no side effects on the engine....... u will feel improvements in the pickup, and if u drive like u normally do, u will notice some savings in terms of fuel consumption
Posted 10 April 2009 - 10:28 AM
Not only brothers, the sifu has spoken.......
Posted 10 April 2009 - 11:01 AM
HAHA,
I think I need to dig back the past posting, need to do home work here.
Its becoz i read in others webpage bout the pulley they installed in satrias, they did mention bout the bearing part. I need to check back.
But seems like many positive feedback going around. Really will look forward on it.
Posted 10 April 2009 - 12:57 PM
Bearing? The bearing is different part leh.....
Posted 11 April 2009 - 07:56 AM
if u use a crank pulley without the rubber dampener, then the criticial vibrations running down the crank will not be cancelled out, thus damaging the con rod bearings and the main bearings........... the only time that u can use those undampened crank pulleys is when u send the whole bottom end for engine balancing..........
as for the dampened versions, those are made to be just plug abd play, no need to take the engine apart for balancing......
Posted 11 April 2009 - 12:17 PM
Heard that the lighten and dampen Mythelogy crank pulley have came out with a new model call F1 edition with Telfon coating on it. Estimated cash and carry item to be priced around RM500 . And Works Engineering have upgrade their material on crank and cam pulleys to T7 aluminium billet which supposed to be lighter than the previous T6 aluminium billet .
