Hi guys, thanks for the feedback. I'll definately get the SC folk to change every single part of the car in exchange for the short-change i am experiencing now. Anyone care to join ?
My greatest worry is the AL4 tranmission. I heard many stories about this car and the pressure device which is prone to give problem. How do I check if it's how a new transmission should behave ?
Just a short description, I took the car for a short drive over the weekend and notice the following:
1. 2nd to 3rd gear switch happens at 3K rpm and above. Else the car will carry on dragging on 2nd.
2. During gear changing, there's a distinct "thud" sound followed by a small jerk. Is this normal?
Thanks for the input again folk!!. Great to know there's still some decent ppl...
-danny
For the AL4 transmission, just remember to use ONLY PSA authorised ATF. Do not try with other brand. It's the same for many advanced box including the CVT, Super ECT (Toyota), etc.
Maintain it well and hope it won't give you any problem, there's few owners which their gearbox is the first version AL4 and still running fine till date.
Also, it is advice to change the ATF every 30,000KM or 1 year (
whichever comes first). You might spend a little more compared to the regular maintenance fee, but I think it's worth it.
Coolant, Brake Fluid should be change/replace every 2 years.
For your car, you might want to pay more attention to the Timing Belt as the lifespan isn't just by mileage alone, there's is duration in terms of "time". Just check it during your 60,000KM service or maybe 3 to 4th year? If you're advised to change, then you should consider it.
Just in case you did encounter any warnings (particularly for the AL4, such as Sport and Snow mode flashing), please follow the instructions in your manual carefully. For the AL4 warnings, it states not to drive over 100km/h and send the car to the SC as soon as possible; In this case, you should not stress the gearbox as it will be working in downgraded or safety mode to prevent damage done. There're stories where owners who ignore or learned to "reset" the warnings (ignore), and soon it become serious.
The gear changing behaviour will need some time to get used to, and just FYI, internally, it has 3 modes:
1. ECO
2. NORMAL
3. SPORTS (this is internal sports mode, which gives you more spirited drive and higher REV or RPM change)
So, if you notice your gear change at high RPM and holding on, it could be the internal sports mode engage, it usually adapts to the driver's driving pattern and switch accordingly. It also take some time to learn and adapt to a new driver's driving pattern/behavior.
There's one owner which complains about the characteristic of the gearbox change after ATF change, which was actually because the gearbox was reset and probably adapted the mechanic driving pattern during test session. Got to know that after sometime, the gearbox was able to learns and adapt back to his driving pattern.
If you feel/suspect the gearbox characteristic or RPM is still not behaving properly, you can complain it to the SC, mentioned about the high RPM gear change; They should know what need to be done.
As for the 'thud' sound, when I test drive the Bestari, I only notice it when I come to a stop or when it shifts down to 1st gear; usually if you're in sports mode or you come to a stop from fast driving.
Other than that, it's very smooth, upshift was not noticeable, but downshift yes, depending on the speed ad gear.
Hi Andy, you mentioend attending Peugeot Club Malaysia AGM. Is this a club or some formal function organized by Peugeot ?
It's the Peugeot Club Malaysia's Annual General Meeting (AGM). This club is official Peugeot Club for Malaysia.
http://www.peugeotclubmalaysia.comWe're truly honoured to have the Marketing Manager from Nasim-Peugeot to be with us during the Meeting.
We also have an unofficial 206 club, called, My206Club, which can stand for Malaysia 206 Club or simply, My 206 Club (for international)
http://my206club.blogspot.comWe also have a forum specially for My206Club under Autoworld's Private Car Club Forum.
If you're free, do join us for any of our TT sessions, and we can talk and learn more about the car, checking out member's ride, experience sharing, etc.
