Dcommander Performance Chip For Commonrail Engine
Posted 25 March 2009 - 11:44 AM
UK Technology
ERC is a power enhancing tuning device suitable for all current models of Common Rail Diesel Engines.
ERC is a simplified piggyback that works on Common Rail diesel vehicles with the initial concentration on the Toyota Hilux and Toyota Fortuner. It is designed to increase diesel commonrail engine performance by adding more horse power and torque with no engine external/internal modification and it uses plug-n-drive technology (with original manufacturer's plugs and connections). It is easy to install and easy to use and does not require complex installation or rewiring of any components. Installation is done by connecting the factory standard connector plugs for the Toyota Hilux and Fortuner that is fitted in line with the standard engine wiring harness, so there is no cutting or splicing of wires.
Impressive torque gains (up to +35%, i.e. Toyota Fortuner) can be achieved, which greatly improves pick up and in some cases even reduces fuel consumption. Horsepower gains can be as high as 25%. ERC works within the original Engine Management System's (ECU) mapped parameters and the maximum achieveable power gains depend on the tolerance range within the OEM computer. ERC works within the OEM manufacturers limits, ensures that at no point the engine is being over-stresses and this also guarantees trouble free long term use because the fuel system is still working within the safe limits. The maximum fuel pressure is at no point exceeded. ERC comes pre-mapped for specific engine models.
ERC features:
- Increase more horse power and torque.
- Ease to install with plug-n-drive technology.
- Easy installation (only connect 2 plugs)
- Maintenance free
- Water resistant
Production Specification
- Increase 20%-30% horse power and torque
Your car will be more responsive.
No need to change any wiring system in your car.
For daily driven cause it will not harm your engine.
*Guaranteed Result*
MONEY BACK GUARANTEE IF NO IMPROVEMENT AFTER FITTING MY KIT !
Available for
1. Toyota Hilux 2.5D Manual or Auto Year 2004 onwards
2. Toyota Fortuner 2.5D
Package includes: ERC and wiring harness
Price: RM700. Price include installation.
Warranty: 1 year
Interested pls call 0193686622 me for further details
Item(s):Max Torque ECU Piggyback for Commonrail Turbo Diesel
Piggyback system for applications of Commonrail Diesels, such as the Toyota Hilux 2.5D or 3.0VNT, Toyota Fortuner 2.5D, Isuzu Dmax Iteq 2.5 / 3.0, Mitsubishi Triton 2.5D, Mitsubishi Pajero Sport and Nissan Navara. It fits directly to each indeendent fuel injector and it is plug and drive type. It also has a On/Off switch, which can be activated or deactivated at any time you want.
This new technology piggyback system, adjust fuel duration resulting increased power and torque figures. This piggyback system, is tuneable, either used on standard commonrail trucks, or on race trucks running aftermarket Turbos.
The Max Torque ECU piggyback features a dramatic changes on your diesel performance. It un-locks the true power potential of a modern commonrail Diesel Engine, electronically. It is easy to install and the results are instant! Most of standard diesel cars are de-tuned from the factory.
Not only will the use of Max Torque Piggyback systems un-lock power from your commonrail engine, we have all the products for whatever purpose you utilize your vehicle for. Need more power for a daily driven truck or climbing up-hill roads on a mountain road or for just fun off road purposes, our piggyback units will make your diesel commonrail vehicle a lot more fun to drive daily.
Can increase 30-40% on horsepower and torque.
*Guaranteed Result*
Available for
1. Toyota Hilux 2.5D or 3.0 VNT
3. Toyota Hiace 2.5D
4. Isuzu Dmax Iteq 2.5 / 3.0
5. Mitsubishi Triton 2.5
6. Mitsubishi Pajero Sport 2.5
7. Nissan Navara 2.5
Demo car available for serious buyer for testing.
All stock standard, only chipped with Max Torque ECU piggyback tuning kit.
Package includes:Max Torque ECU, wire hardness, and on/off switch.
Price:Please PM for price
Warranty: 1 year
Interested pls call 0193686622 or PM me for further details.
Age of item:New
Posted 17 June 2009 - 09:56 PM
Posted 19 June 2009 - 12:37 AM
tazztham
Posted 24 June 2009 - 10:52 PM
My workshop near Jalan Kuching, KL. No need to dyno before and after cause guaranteed result. If no differences after installing my unit, I will take it out immediately without extra costs.
Posted 26 June 2009 - 02:12 PM
Posted 29 June 2009 - 05:56 PM
If you remove it or switch it off when sending to service centre should be no problem cause they would not notice it and it will just be like original condition before you install my Dcommander. Any new device you install for performance purposes other than OEM parts will void the warranty for a new car. Thanks.
Posted 29 June 2009 - 10:55 PM
Posted 30 June 2009 - 07:07 PM
Have you fitted to a Chevrolet Captiva LT Diesel?
Posted 01 July 2009 - 12:47 PM
hi br1,
i am not sure for Dcommander if it can be fitted or not, but i can tell u more than 20 captiva is running with Vector in town. check it out.
Vector Tuning
thks.
tazztham
Posted 07 July 2009 - 07:42 PM
It is difficult for me to write about how these things work here cause will be very long. A brief idea is it is similar with vector but the difference between vector and dcommander is that mine is adjustable while vector is non-adjustable. Your engine will last much longer because the factory settings increase will not harm the engine life but if you want custom settings that will depend on your engine current condition and driving habits. Maybe if you wanted to know more, bring your car to my workshop and will demonstrate and explain to you how the dcommander works.
