My Waja Maintenance Cost
Posted 26 June 2009 - 06:13 PM
Cemerlang Gemilang Terbilang dan Terus Hilang
Posted 26 June 2009 - 09:22 PM
pirate 1
Posted 29 June 2009 - 04:09 PM
Differential fluid 40000 24
What is Clutch Fluid and Differential Fluid?
Attached is the preventive maintenance plan from PE at Subang.
Ford Telstar TX5, Proton Waja
Current Ride:
Peugeot 308
Posted 29 June 2009 - 04:54 PM
clutch fluid is for manual transmission 1
for automatic transmission you'll need ATF fluid
i check already auto/manual waja don't need differential fluid cause it is "built in" with gear oil. Correct ar?
by the way, the pdf attachment is not exclusively exhaust to list out everything (like suspension & brake)
Posted 29 June 2009 - 05:04 PM
oi yo!
sf, your nose bleeding le
for the analysis i use "miklusor opit eikcer"
Posted 29 June 2009 - 05:54 PM
Yalor...to hot already...
Posted 30 June 2009 - 10:08 PM
correct, the list is not exhaustive..
i guess parts such as suspensions, brakes, clutch kits, etc are dependant on style of driving.
cheers!
Current Ride:
Peugeot 308
Posted 13 October 2009 - 12:03 PM
Hi bro kohf1drive,
I also experience the annoying "nyek nyek" sound, what's the "trailer arm link" you're saying? How do you solve the problem?
Posted 13 October 2009 - 12:30 PM
Hi bro kohf1drive,
Ah koh, u never change power window bracket and door handles yet
U hardly use the power window and ask people to sit in ur car izzit
