My Waja Maintenance Cost
kohf1drive
, Feb 13 2009 11:35 PM, 80 replies to this topic
Posted 14 February 2009 - 10:26 AM
QUOTE (kohf1drive @ Feb 13 2009, 11:35 PM) <{POST_SNAPBACK}>
ok ar?
Ah koh ar..... you think I have perfect eye sight izit? My each eye short sighted about 400 degree ler.
Posted 14 February 2009 - 01:57 PM
QUOTE (SplitFire @ Feb 14 2009, 10:26 AM) <{POST_SNAPBACK}>
haiya, compressed ma. limited upload size la
click this link
http://kohf1driver.b...friendster.com/
my humble modenas kriss 100 routine maintenance not even the price of my waja full tank!
Posted 14 February 2009 - 09:28 PM
wah so much ar?
much2 more mahal than my Honda,BLM and my dad's darkhorse.the darkhorse can be exempt bcoz its rarely used.
still,more mahal than the maintanance of my honda and BLM put together.
Posted 14 February 2009 - 10:04 PM
QUOTE (Gunnerzz @ Feb 14 2009, 09:28 PM) <{POST_SNAPBACK}>
wah so much ar?
But you must know most item you change already no need to change again for a very long time.
I din know you always play around Desa Tebrau & Gaya?
Are we neighbour?
Posted 15 February 2009 - 12:15 AM
QUOTE (SplitFire @ Feb 14 2009, 10:04 PM) <{POST_SNAPBACK}>
Are we neighbour?
Are we neighbour?
i don't play play around there la
i get some free knowledge in desa tebrau
while in desa harmony, i "set up" the car
across the bridge johor jaya, i do test drive at a specific traffic light
Posted 15 February 2009 - 10:35 PM
Component Items Service interval (km) Service interval (months)
Engine
Engine Air Intake Filter 20000 12
Engine mounting 100000 60
Engine Oil 10000 6
Engine Oil Filter 10000 6
Radiator Coolant 40000 24
Radiator hoses 100000 60
Spark plug 60000 36
Timing belt, bearing, & oil seal 100000 60
Tranmission
Clutch fluid 20000 12
Differential fluid 40000 24
Gear oil 40000 24
Suspension
Bush don't know
Damper depend
Power steering fluid 40000 24
Steering Bush 100000 60
Brake
Brake fluid 20000 12
Brake pad depend
Fuel
Fuel Filter 60000 36
Tire
On/Off wheel balancing depend
Rotate 10000 6
Tire depend
Wheel alignment depend
Accessory
Air cond servicing 30000 18
Battery depend
Windscreen wiper depend
These are what i gather from the net, correct ar compare to manual?
Engine
Engine Oil 10000 6
Spark plug 60000 36
Tranmission
Gear oil 40000 24
Suspension
Bush don't know
Damper depend
Brake
Brake pad depend
Fuel
Tire
Rotate 10000 6
Tire depend
Accessory
Battery depend
Posted 17 February 2009 - 10:02 PM
QUOTE (baldwin @ Feb 17 2009, 03:29 PM) <{POST_SNAPBACK}>
(for OEM parts)
spark plugs every 20k
brake fluid every 40k
baldwin, you're wanted at NMT 2009. Please register wif Jaime che che then drop by ok?
