Engine Overheating
rikeys
Posted 07 December 2009 - 10:47 AM
rikeys
  • 9,391 posts
QUOTE (Hammercar @ Dec 7 2009, 10:35 AM) <{POST_SNAPBACK}>
if ur fan is running, and ur mileage is high...have you change your water pump on ur last timing belt change?
culprit may be your water pump. change to a Japan one......
now where got japan ones! japs one veli mahal lor if the price is cheap sure not 100% from japan kakakaka
Join MyFORTE: Forte Owners Club - Facebook Group now! Be part of the growing Forte family..
Bookmark this now - www.myforteclub.com
#32
kolejeon
Posted 11 December 2009 - 08:54 AM
kolejeon
  • 15 posts
QUOTE (kokoko @ Dec 7 2009, 12:35 AM) <{POST_SNAPBACK}>
Mr Kolejeon, is it your problem really solved, since your posting 4 months ago. I just faced the same problem recently, and I replaced hose, thermostat, fan switch, air cond filter, servicing air cond, and the problem still not solved. My mechanic said that everything is fine and they also puzzle about this problem.
Hope you can share your experience about it
Bro Kokoko,
My problem had solved. u can check my previous posting. dont change the other parts. the culprit is fan motor. eventhough it is working, the fan rotation speed has deteriorated. Just change the fan motor and i bet everything will back to normal. I sent the car to Proton Service and EON service. Proton service can't detect the problem but EON service solved the problem. But i suggest u change it outside because of cheaper price.
#33
wangi
Posted 11 December 2009 - 10:46 AM
wangi
  • 190 posts
QUOTE (kolejeon @ Dec 11 2009, 08:54 AM) <{POST_SNAPBACK}>
Bro Kokoko,
I thought the fan motor would have sound when it going to breakdown? This happen to me in wira last time, the sound last me almost a week then only the fan motor "kong".
#34
clsia1001
Posted 16 December 2009 - 05:34 AM
clsia1001
  • 148 posts
mind to share how much is the motor cost??
S i A
#35
Sufianfix
Posted 29 December 2017 - 01:05 AM
Sufianfix
Hello guys i have gen2 pro i got some problems regards the high temperature specially in hot weather or during the AC is open however after i read the comments i think i got the solution thank you guys i will try to clean the radiator first if still having this issue i think better to change the radiator it self. THANK YOU ANYWAY
I HAVE QUESTION GUYS CAN YOU GUIDE ME WHERE EXACTLY I CAN FIND SPARE PARTS FOR GEN2 as im looking for window swichs and AC swich also the steering wheel cover. Plz anyone can help me.
#36
Sufianfix
Posted 01 January 2018 - 02:34 AM
Sufianfix
Hello guys i have question about gen2 overheat problem actually it couod be anyrhing in my country we sometimes remove the thermostat to let the water goes faster and not become hot anymore but im wondering should i i do the same to gen2 or it will be a major problem as cars have thier differences
#37
Posted 02 January 2018 - 05:56 PM
  • PipPipPipPipPipPipPipPipPip
  • 69,745 posts
Never remove thermostat to help cooling. Got overheating problem fix it the proper way. Taking the thermostat out, the engine may not run at optimum temperature and more wear will occur....
