Engine Overheating
Posted 30 December 2008 - 11:20 PM
I'm driving 2005 gen2 MT. Having serious problem recently with my ride. I was trapped in traffic jam at noon and noticed the engine temperature overheat until reached the red zone. I have to stop before continue my driving. It happened many times during traffic jam and back to normal temperature during normal speed. I regularly service my car at every 5K km and changed the radiator coolant at every 20K km as advised in the service manual. Current mileage already reached 109,000 KM. Appreciate advice before send the car for repair. Thanks guys.
Posted 31 December 2008 - 01:58 AM
kolejeon, if coolant level is ok, then i think it is your radiator fan not working... with no fan cooling, engine temp go up when car not moving and no wind coming to the front. You can test it by, start the engine, leave it and let the engine temp go up, normally if the engine temp go higher than 50% of gauge, the fan will run... if the fan still not run, confirm the fan not working already. next, check and make sure the wire connected to the fan motor are connected properly... if wire connection is ok, then likely the motor or the automatic temperature switch fails already.
Posted 31 December 2008 - 08:03 AM
check your thermostat and fan.
Posted 31 December 2008 - 11:19 PM
However, I noticed the radiator fan is still running eventhough i had switched off the engine during high temperature. It keep on spinning for 10 minutes during engine off. So I could assume the radiator fan is still working properly right?
The engine temperature back to normal and the fan stopped automatically after I restart the engine for several minutes before continue my driving. If the fan is not the culprit, what else?
Posted 01 January 2009 - 12:22 AM
that looks like your fan is running fine, only the temp is higher. Double confirm your thermostat, if necessary flush your current coolant and fill up with 100% Proton coolant (no water added). Other then that, check your engine oil level. Btw, where you changed yur coolant? I worry those mechanic did not do breathing for your radiator or the breathing period is not enough to remove all the trapped air.
Posted 01 January 2009 - 09:36 AM
Posted 01 January 2009 - 12:23 PM
Posted 01 January 2009 - 02:07 PM
what coolant do they use there ?
Posted 01 January 2009 - 02:28 PM
could be a blown gasket , lots of air buble in ur hoses , or broken water pump fins...if i bet...i wd go for water pump maulfunction
