Brake Pads
jonlsl
Posted 24 November 2012 - 07:16 PM
jonlsl
  • 2,013 posts
QUOTE (eddievh @ Nov 24 2012, 04:03 PM) <{POST_SNAPBACK}>
Above 100C may be.
No use talking about the trestor 2star lah. Can get other cheapo pads which work better with the same money so why even bother talking about it other than recommending people not to use it.??????
#522
Posted 26 November 2012 - 02:25 PM
  • 71,517 posts
QUOTE (eddievh @ Nov 24 2012, 02:55 AM) <{POST_SNAPBACK}>
No la, Trestor 2 star hot performance not that bad la but cold performace is really quite bad need big muscular leg.
Is that the Trestor semi metallic?
QUOTE (jonlsl @ Nov 24 2012, 07:16 PM) <{POST_SNAPBACK}>
Then it should be the lower grade ones......
#523
fkmfkm
Posted 27 November 2012 - 11:49 PM
fkmfkm
  • 5,021 posts
Above 100C may be.
what 100c is not bad hot performance ???
#524
Posted 29 November 2012 - 11:08 AM
  • 71,517 posts
QUOTE (fkmfkm @ Nov 27 2012, 11:49 PM) <{POST_SNAPBACK}>
2 star not lower end pads meh? I thought lower end good for cold use and not high temperature?
#525
jonlsl
Posted 29 November 2012 - 12:11 PM
jonlsl
  • 2,013 posts
QUOTE (vr2turbo @ Nov 29 2012, 11:08 AM) <{POST_SNAPBACK}>
Thats why so lousy 2 star lagi cannot stop hot or old. At least other lousy can stop cold. Hopeless.
#526
mot88
Posted 01 December 2012 - 08:46 AM
mot88
  • 103 posts
Agree on the 2 Star Trestor, it performs even worse than the stock local made Mintye. Once used it less than 1k km and decided its not worth the risk.
#527
Posted 03 December 2012 - 10:45 AM
  • 71,517 posts
QUOTE (jonlsl @ Nov 29 2012, 12:11 PM) <{POST_SNAPBACK}>
Oh! that bad, means Bendix General CT is very much better..... smile_tongue.gif
#528
jcetham007
Posted 10 December 2012 - 01:53 PM
jcetham007
  • 296 posts
QUOTE (vr2turbo @ Dec 3 2012, 10:45 AM) <{POST_SNAPBACK}>
Hi vr2turbo,
Do you know of any other shop/outlet that sells Bendix GCT DB 1504 brake pads for Sonata NF 2.4 (2006)?
I called up PH Auto, Sea Park but they say they do not stock this model.
I intend to replace original Hyundai brake pads with DB 1504.
Your assistance is much appreciated.
Thank you.
jcetham
#529
eddievh
Posted 10 December 2012 - 05:15 PM
eddievh
  • 1,763 posts
QUOTE (jcetham007 @ Dec 10 2012, 01:53 PM) <{POST_SNAPBACK}>
Hi vr2turbo,
Thank you.
You can try and ask those pad seller in Lowyat ,
http://forum.lowyat....hlite=Brake pad
#530
jonlsl
Posted 10 December 2012 - 06:21 PM
jonlsl
  • 2,013 posts
Hi vr2turbo,
Thank you.
You can also try the other spare parts shop near PH auto. There are afew around the area. There is a whole stretch directly opposite facing the shell station facing the main road where PH Auto is. I bought my Cefiro Bendix GCT from one of those shops. IF don't have can sure ask the spare parts shop to order mah.
