Lubegard Kool It
Posted 26 December 2008 - 12:18 AM
i never use with any coolant. I thought these are already coolants by itself? it says on the bottle that 1 bottle of Kool It treats up to a certain amount of quarts of coolant. i thnk is 20, cant remember now.
So far i never had any probs, no leakages or whatsoever.
Posted 27 December 2008 - 10:04 AM
without coolant will the water boil?
- My name is goreng
Posted 27 December 2008 - 12:08 PM
If you mean just water in the radiator. Whether with or without coolant, the water will still boil. It depends on how high is the running temperature. The coolant not only aid in cooling but to prevent rust as well as to lubricate the water pump.
Water in radiator system boils only at higher temperature as it is under pressure.
rdgs,
Posted 27 December 2008 - 08:09 PM
Posted 29 December 2008 - 01:17 PM
Another thing, do I need to change the water pump at 100k km interval when changing my single belt (steering, alternator, fan) during my next service? My car is gonna be 4 yr old next Feb.
Pls advise. Thanks.
Posted 30 December 2008 - 10:13 AM
For Kool-it, the bottle lable is stated just like Redline WW, added water will do, not need coolant.
it is good to change Water pump as part of the maintainence part.
i change it at 80k km during timing belt service..it still look good and many of friend with same car with me drag it till 200k km without problem.
but i still insist change it during my next timing belt service which is real soon.
Posted 30 December 2008 - 12:32 PM
I thought u only need to change it if faulty ?
www.duragloss.com.my
Posted 30 December 2008 - 02:28 PM
So, unless if your WP is very expensive or of industrial strength, it's cheaper or more convenient to just change it together with the TB. The Iswara's WP only costs around RM60, and that's for a Japanese-made unit, so quite cheap lah. Maybe mubull's MPVs have much costlier WPs!
> XLIQ <
~ Think great oil at great price, think Esky ~
Amsoil | German Castrol | Royal Purple | Mobil 1 | Mobil 1 EP | Motul
Posted 30 December 2008 - 06:08 PM
Posted 31 December 2008 - 09:09 AM
1 week ago a did a completer radiator flush and then added in a bottle of Kool IT. A few days later I noticed that the mixture of water + coolant in my reserve tank is almost full but when I open the radiator cap, it was not full as I could pour in 500 ml of water. Sent my car to the workshop and had to change the main radiator hose (slight leak) plus 2 smaller hoses. Since I have never changed the thermostat and fan sensor, I asked the mechanic to change them as well. I am still experiencing water overflowing to the reserve but not fully drawn back to the radiator (radiator is not full when engine is cold). I am just wondering if this is normal or if there is something wrong with my car.
