Vios J: no intermittent viper option
Posted 09 December 2008 - 10:39 AM
available in other type. Izzit that we can't choose to wipe once on the
windscreen that is what mean by above?
Posted 09 December 2008 - 12:43 PM
ever seen.
The intermittent wiper setting (labelled INT on the stalk)is the one
where your wiper sweeps the windscreen once every 2-3 seconds. It's
usually at the position just after 'OFF'.
Some cars even come with variable intermittent settings where you can
vary the period between each wipe.
I was quite amazed when my friend told me the Vios J did away with this
feature. I thought he was referring to the variable intermittent function
until I test drove the car.
However, the driver can manually activate a one-time wipe by pushing the
stalk upwards.
Posted 09 December 2008 - 12:59 PM
Very fast wipping speed that will wear off the viper blade?
Posted 09 December 2008 - 01:34 PM
speed is the ON? Or is it ON with 2 speed only?
Posted 09 December 2008 - 03:31 PM
I believe there's also the manual one-wipe toggle, where you push the
stalk up, the wiper wipes once, and that's it.
Posted 09 December 2008 - 09:39 PM
higher end Vioses in to yours?
Posted 11 December 2008 - 01:27 PM
AUD15K
Posted 12 December 2008 - 11:39 AM
happen to the Avanza.
Posted 22 December 2008 - 10:10 AM
There are many other car a lot more expensive than Vios that does not have the adjustable intermittent wiper.
Just leave it at the default single speed intermittent position.
