1st Vios Car Key Worn Out.
Posted 04 December 2008 - 03:25 PM
I have both my vios (1st generation vios) car key worn out, holes on the
alarm button,
anybody have any suggestion / experience on replacing this? I am not happy
with the current key design and trying to avoid using back the same key
housing...
External workshop charge for RM 90 to replace a new "original" key housing..
Posted 04 December 2008 - 05:06 PM
change the casing. understand that they now have a better rubber material
which should last longer. or they also have new design if u want to, but
the price a bit on the high side.
Posted 04 December 2008 - 06:57 PM
Are you sure it's cheap?
For your info, the price stated the TS (Thread Starter) is quite cheap
already. What I can tell you is that a member of Cobra tells me that the
replacement for the casing cost RM120 because the key is glued to the
casing which makes it impossible to replace the casing. What they will do
is ask you to bring new spare key to duplicate another one and then glued
it to the new casing for RM120.
BUT if you car is still under warranty, YES, COBRA WILL DO IT FOR FREE,
which mean no charges at all. Just bring your new spare key and they will
duplicate one to glued onto a new casing without any charge. Oh, remember
to being your service book to prove that your car is still under warranty.
Posted 04 December 2008 - 07:59 PM
holes. i bought one in UMWSC, the casing which sticks to a new uncut key
only costed me RM35.90, and it's free to remove the chip inside from the
old key to the new casing. so the old casing is empty inside but the old
key is forever stuck there, as spare key. if i want to cut the new key,
then i have to go outside to duplicate one, then i will have 3 keys. how
come u all got it quoted so expensive? i went to the Ipoh UMWSC.
Posted 05 December 2008 - 01:52 AM
also replaced mine before.
Posted 05 December 2008 - 03:58 PM
so never mind la..
Posted 05 December 2008 - 04:07 PM
price now is RM10.90. if during service, can even get it change with free
labour.
it seems independent workshop charges more expensive than UMWT.
other dates. changed the key near the end of last october.
Posted 05 December 2008 - 08:56 PM
housing at external workshop.
I am from Butterworth, penang.. Will try my luck at Prai Service Center.
