S40 2.4i: Vibration @ idling
Posted 21 September 2005 - 03:53 PM
Any owners of the S40 feel their cars vibrating when idling on neutral?
It feels very much like the engine is misfiring or the mounts are lose.
Appreciate some feedback if anyone has encountered this and got it
resolved.
Cheers,
kfvwong
Posted 21 September 2005 - 04:57 PM
generation S/V40 , our S/V40 had been known on this issue world
wide mainly on the engine mounts ,
mm.....misfire, normally happen on those old car , your is so new.
may be not, our happen mostly due to the spark plug cable coil are
cracked.
should sent back to workshop for checking as it is still under
warranty.
and up date us after the problem is solved
Posted 24 September 2005 - 09:59 AM
send for repair immediately.
Posted 25 September 2005 - 12:19 AM
type.. since the engine suspension is a pendulum design, its quite
sensitive to vibrations..
Posted 10 November 2005 - 11:18 AM
Quick update. Found this solution to what I believe is causing the
vibration (see link below). Just sent my car in ... hopefully it'll be
fixed.
http://www.alldata.c...20400000_TNN21-
21/index.html
Rgds,
Vernon
p/s: If you're free, you can go through the whole catalog of bulletins ..
there are a few fixes of problems you may not even know could be fixed!!
Posted 10 November 2005 - 10:52 PM
my new S40 also got this problem, it is like engine vibration and I do
feel like a little bit of misfire, all these are obvious when it is on
neutral gear idling.
Are you sending your car for checking? To FA or SM? Please let me know
the outcome, I'll arrange one day to send in for checking too...hopefully
small matter..
Posted 11 November 2005 - 12:29 PM
how do u show the mechanic regarding the way of repairing? ask him to
surf this website??
pls keep us informed. thanks
Posted 12 November 2005 - 12:25 AM
btw.. all the bulletins are actually from VCC but in US it is OPEN to
public about all these 'recall' even though just a 'soft recall'.. and
need to know that VOLVO US-CANADA specs are lot different from us malaysia
market especially related to powertrain, emission and safety..
Posted 12 November 2005 - 11:29 AM
any ideas what is it due to? The engine mounting? Any solution for this
so far?
Posted 14 November 2005 - 01:53 PM
