940 Head Light Not Bright
Posted 15 February 2005 - 06:18 PM
CNY. Thinking of changing the light bulb. Any advise for a brighter bulk &
what is the spec.. where to get them & cost estimate...? Thanks!
Posted 15 February 2005 - 06:37 PM
reflector, and it got very2 bright again....
Posted 16 February 2005 - 12:02 PM
What's the cost like for 240 reflectors? Perhaps 940 one not much
difference..
Posted 16 February 2005 - 04:49 PM
at first i thought mine's not bright oso then i noticed that the lighted
patch was just 6 to 8 ft. from the head so i adjust it higher
Posted 16 February 2005 - 05:20 PM
reflector (but don't run the reflector please). Takes you about 3 hours to
remove the whole assy and re-install.
Posted 16 February 2005 - 05:26 PM
did was to soak the reflector in soapy water & then rinse it with running
water.
Posted 16 February 2005 - 05:36 PM
(complete set with seal rubber & clips)
i'm not sure with 940 one...
yup, upon my readings, reflector will easily 'ruined' once touched (am
wondering if the water from our hands contribute to 'rust' there?
Posted 16 February 2005 - 08:16 PM
thats expensive zhafri
i got the full headlamp assembly for rm170 only leh
this includes lens reflector casing seal bla bla bla
of coz taiwan mali la... quality like sh1t
Posted 16 February 2005 - 10:43 PM
months to come)... very good so far.... i did change the whole unit of side
lamps-quality mmg betul2 teruk, size tak sama dengan ori.... what to do,
don't have money... ehehehhehehe.... at least, both rear & front look new
now.... eheheheh
Posted 17 February 2005 - 11:44 AM
hands likely has some chemical re-action to this reflector. and i also
heard the same goes for bulb.
my opinion would be to take out and see if the reflector still shine and
no rust like, then wash it. if rust, can afford, change to ori. change to
a higher bulb voltage(i.e100watt) not recommend as it will fade away the
reflector in time.
i guess with new car having new reflector(even my wife kelisa)so bright,
we tend to assume our lights no longer bright but in fact its the same
except for some whom could be due to dust set it during the years.
