oii..I replied first thing in the morningler.
Anyway, most transponders have a small IC chip that stores the code. If
someone can duplicate it, they will need to flash an IC with the same
codes to make it work.
An immo weakest link is the Transponder..its so easy to get broken if not
handle with care...sometimes, this IC can die by itself also.
Try opening the transponder and solder back all the circuits...if you are
lucky, it will work...if not, go and find a new immo system...sighs.
The biggest trouble of immo is dismantling it....thats the worst part.
transponder for immo cannot scan....
waikhei
, Aug 30 2006 10:52 AM, 12 replies to this topic
