1989 Alfa 164 (m) 3.0 v6 enquiry
#51
Posted 30 October 2005 - 06:51 PM
100kmh in 10sec compared to 0-100 8sec is like worlds apart.
#52
Posted 08 November 2005 - 10:52 AM
My 168 AC don't seem to do its job very well. What mods have you guys done
to get the AC to work much better and where did you go to? Oh yeah.. what
was the damage to the wallet?
#53
Posted 08 November 2005 - 02:32 PM
Before you go about changing stuff in th e system, I suggest you do a
conputerised diagnostic first to pin-point the problems that may be
present.
Th3re may be different types of gases inside,plus water and hydrocarbon
contaminants which will lower the cooling efficiency. Also it can measure
the amount of oil that can be recovered and impending compressor failure.
The type of compressor oil used before is also a major factor that can
affect the compressor efficiency.
Cheers
#54
Posted 08 November 2005 - 02:41 PM
Much obliged on your feedback mate!! Where can I go and do this comp
diagnostic?? Also.. Does anyone know whether the 1992 164 12V is equipped
with OBD II??
#55
Posted 08 November 2005 - 06:24 PM
ada satu kedai air cond dekat SS 5 kelana Jaya..same row with Bank
Simpanan Nasional and 7 -11 ada Comp diagnostic Mechine..baru
diperkenalkan diworkshop tu just before Puasa..next to Kelvin alpha air
cond shop row...
#56
Posted 09 November 2005 - 08:54 AM
done is to identify the fault and not many A/C people can do it.
I did a general service at Kool Aire Sunway last few years, change the
blower (RM600-new), change the compressor (RM450-recond), valve, thermo
amplifier etc. Cost me about RM2k for all and to date it works just fine.
I did bypass the heater function,....but now I will probably want to
connect it back so that the climate control function works as it should
be. Probably will be visiting Dino at freshtool when I have the time to
seek for parts to get the heater functioning again.
#57
Posted 09 November 2005 - 01:43 PM
I'll try hunt for that shop you mentioned Pinin. The air cond is just so
crap compared to the Giulietta...
#58
Posted 09 November 2005 - 02:17 PM
164s/168s? I'm obviously interested in the 3.0 12V but I'd also like to
know the consumption for the 24Vs and the 2.0 TS
#59
Posted 09 November 2005 - 02:42 PM
open pod filter, grounding wires and a DIYed voltage stabiliser.
