#301
mawiloco
Posted 20 September 2010 - 01:42 PM
[/quote]
i got this hub
yijia from thailand..cost me around rm450.00..per pair...hati ada sikit senang sekarang..
For tyre i got rm 370 including balancing, alignment, and all filled with Nitrogen gas..
Silverstone AT 117 Special - 265/70/R16
#302
ShiftVQV6
Posted 20 September 2010 - 02:55 PM
i got this hub yijia from thailand..cost me around rm450.00..per pair...hati ada sikit senang sekarang..
For tyre i got rm 370 including balancing, alignment, and all filled with Nitrogen gas..Silverstone AT 117 Special - 265/70/R16
wow, look nice.
how much u pay to install it?
#303
mawiloco
Posted 21 September 2010 - 08:25 AM
wow, look nice.
bout 50 bucks..25 each side...
1) Now another prob..
steering box got leaking and im not satisfied with the free play..too much free play on the left , on the right is ok..told them to adjust the screw for the
left side only, but they said its not possible..emmmm?????
Check with fren prado..them using steering rack..good response...wonder if isuzu can change to rack system
2) When using AT tyre like SILVERSTONE..i feel a bit of a harsh ride..is it bcoz of its compound? and it also raised up bout an inch..will it affect the stableness of the car..??..feels a bit wobbly..i just the balancing, alignment not yet done..
#304
ShiftVQV6
Posted 22 September 2010 - 04:14 PM
bro, seem like endless problems with ur BH huh..... mine also no better....
currently, my 1st and 2nd gear hard to engage when the car just started for the 1st time..... when the car warm up after few minutes, no more this issue.... what could be the problems?
Posted 22 September 2010 - 04:37 PM
Did you put engine oil like 15W40 in gear box? You should.
I prefers to use my head than follow the crowd. After all, it is my money and not theirs.
#306
mawiloco
Posted 23 September 2010 - 08:42 AM
mine ok so far..i used 15w/40 engine oil, info from the forum,,tq...but i use semi snythetic oil, just to try,,rasa halus, can feel the gigi gear..
next change, i want to try 15w/50 engine oil..wonder what it feels like..
- i think maybe 2 possibilities...1) the clutch adjustment . 2) the gear oil, maybe dah kurang...
Biasala bro ,problem,kadang kadang syok,kadang kadang rasa nak buang dlm lombong..hehee..sabar .sabar..
I bought myself a creeper, greasing and oil change by me now...
Before Raya ia also change , cross end bar ( for steer ), at front ,,damm expensive rm 450 for a rod..i thought i could less the free play , but ..naaahhh.....need to operate the steering box..plus its leaking anyway...
Posted 23 September 2010 - 10:36 AM
Make sure the 15W50 you wanted to use is Fully Synthetic. For 15W40, Mineral is perfectly fine.
#308
ShiftVQV6
Posted 23 September 2010 - 04:27 PM
in earlier post, some one mentioned the following
"engine oil 20W-50 for transmission and transfer case, 80W-90 GL-5 oil for rear axle oil"
so, which one should i use now?
Posted 24 September 2010 - 07:24 AM
Transmission case is where you shift the gear and I suggest may be you try 15w40. Axle is the 'ball' shaped thing at the rear joining the 2 rear wheels.Two different thing.
#310
mawiloco
Posted 24 September 2010 - 09:05 AM
Tourist..thanks for the info..lucky i didnt change it yet..
What would happen if i use 15w/50 that are not fully synthetic..will it damage the gear box...
This rear axle oil..i use the Toyota LSD oil...cant remember the numbering...
