air-con
Posted 16 February 2005 - 05:47 PM
all vitara's air-con is like that, cos the fan is "thin", atleast change a "thick" one, will b
very cool..... n it cost me RM400 (a boom)... curious to ask all VITARA menber,
hows your baby's air-con......????
now my baby got air-con like no air-con :"(
Posted 16 February 2005 - 06:25 PM
What is the relation between fan thickness & cooling level ???
blurrrrrrrrrr
Posted 16 February 2005 - 06:36 PM
that why i never fix my air-con at his place.. need sifu help.... i hope dun spend too
m,uch money ah..:(
Posted 17 February 2005 - 10:35 AM
it's true... but still doubt of it.....if u try it do let me know the
result....... i still think this is very funny & no..sense...
Posted 17 February 2005 - 11:38 AM
if its cold at nite (cold nite lar, not current hot nite) then maybe your current
fan is not good enough (for same rpm, similar diameter fan with thicker blade
should give more airflow).
good news is chop shop fan is only abt 50rm, add a 10rm relay n u should be
ok
only problem u might encounter is space
Posted 17 February 2005 - 12:30 PM
hmmmmm
blurrrrrrrrrrrrr
Posted 17 February 2005 - 01:18 PM
itu layman term lar, if u want to go into detail then u need to consider
blade area, blade angle, blade design, blade rpm, inlet design, exhaust
design, etc, etc.
basically if the a/cond is cold when ambience is cold then it means your
cooling fan performance is insufficient and u need a higher performance
fan, its totally up to u what kind of fan u want, thinner or smaller or
whatever as long as it can provide a significantly more airflow.
Posted 17 February 2005 - 04:22 PM
relation at all from air con performance. All other things that u said
make sense lor........
for me the thinner the better it is as less as long as the thickness can
stand maximum speed....less heat produce lor....less power need to spin
it.... just my 2 cent tot ....
anyway don't angry ahh... i have no knowledge at all on this.... just
simply my tot....
Just difficult to believe thing that sound so ......
he he..
Posted 17 February 2005 - 05:54 PM
in if u look at it from the side the whole thing would be thicker, not the
fan blades it self lar.
for example,
ceiling fan is thin
table fan is thick
the blades itself for both of the above fan is the same
Posted 17 February 2005 - 06:31 PM
that why i told u silly question.... ekekekeke
he he.. just kar po chi sikit lor....
