Camry 2.0/2.4 Discussion
Micky78
Posted 25 May 2017 - 10:48 PM
Micky78
  • 71 posts
Dear Vr2,
your SUV problem resolved yet?
i have send my car to toyota and when they run the diagnosis, no error msg come out. at the end they clean my throat body and set my idle higher..
after one mth problem seem come back but not serious unless engine die off...
now i try not pump till fulll tank and see whether any help or not..
i still enjoy driving this car, hope this problem can resolved...
#632
Posted 26 May 2017 - 09:49 AM
  • PipPipPipPipPipPipPipPipPip
  • 69,545 posts
Dear Vr2,
Nope, not yet. Since problem only when refuel I also just left it like that. Kick the starter longer, step on accelerator not to let engine die off then everything back to normal, until next refuel.......lol
#633
Micky78
Posted 26 May 2017 - 07:08 PM
Micky78
  • 71 posts
Too bad for both of us...
#634
Micky78
Posted 17 September 2017 - 09:54 AM
Micky78
  • 71 posts
hi all,
need to seek advice. ytday want to check my brake, the mech told me my brake pad only remain 20% and need to skim the disk brake.
my question is as follow:-
a) i cannot change a new brake pad now as better off the skim the disk brake then change the brake pad... is it true?
B) so far no laud noice when i brake.
#635
Posted 17 September 2017 - 04:42 PM
  • 69,545 posts
hi all,
Usually you will require to skim the disc rotor if:
1) When during high speed braking you get a lot of vibration from the steering wheel
2) The disc rotor worn uneven and/or have many worn deep lines
Nowadays for some car make, the disc rotor replacement is not very expensive. Maybe you should check the price first as you already need to pay for skimming, maybe can add a little more for new disc.
Skimming disc also need a minimum thickness, too thin already then cannot skim....
#636
Micky78
Posted 17 September 2017 - 06:00 PM
Micky78
  • 71 posts
 thanks for sharing.. will do some survey whether to skim, get a after market part or new disc..... no problem when in high way and my speed only below 100mph...
#637
Posted 18 September 2017 - 08:26 AM
  • 69,545 posts
Probably the rotor have many deep grooves already that is why your mechanic advise to skim. My friend's Myvi seems he can get a pair of disc for like RM120, skimming already like RM80, so he rather get new disc.....lol
If for your car the disc is not cheap then skim it.....
#638
scenic
Posted 22 January 2019 - 02:26 PM
scenic
  • 3,156 posts
Hi there,
Any of the Camry owner still around in AW ? :rolleyes:
director's choice
#639
Posted 23 January 2019 - 08:14 AM
  • 69,545 posts
Hi there,
Forum almost dead, most are into fb already........
#640
Posted 23 January 2019 - 08:15 AM
  • 69,545 posts
Dear Vr2,
Hi Micky,
Lately my problem gone, don't know why also. Now pump full, can start like normal.......lol
