Let us know the outcome.....
Camry 2.0/2.4 Discussion
#622
Posted 06 July 2016 - 09:27 PM
within these time.. i head one loud sound seem fr beneath engine... then no more sounds....
any idea? tq..
might only send for check next wks
#623
Posted 03 February 2017 - 12:47 PM
Im looking to buy a 2.0 or 2.4 camry ACV30/31, if youre looking to sell, pls message me.
Thanks
M
#624
Posted 26 April 2017 - 07:10 PM
My acv30 engine will vibrate after I pump petrol.. today worst... Engine die off few time.. lucky got Toyota SC nearby n send in for checking... Conclusion. SC also can't diagnosis out what problem.. only reset ecu n clean throttle body. Now back to normal...
Any idea what happenn.. no error code come out at machine reading..
#625
Posted 26 April 2017 - 09:27 PM
Need help..
Wait till next refill and see if same problem arises? My Chery SUV having this problem. When open fuel cap to refill need to crank longer to start and if don't step on accelerator might die off. But once started no issues until next refill....
#626
Posted 27 April 2017 - 12:21 AM
usually i wait til the fuel alert come out then i will refill.. maybe i will try to refill after 3/4 tank empty..
#627
Posted 24 May 2017 - 11:49 AM
Hope situation won't turn to worst.
#628
Posted 24 May 2017 - 05:15 PM
Maybe just low idling speed. FICD not working properly? If off air con, how is the idling?
#629
Posted 25 May 2017 - 01:26 PM
Btw, what is ficd?
#630
Posted 25 May 2017 - 05:37 PM
Yes aircorn not on also low idle then back to normal , only got problem after pump petrol. I Always goto different shell station pump petrol but still same.
Btw, what is ficd?
FICD is Fast Idle Control Device, helps when air con kicks in. When air con kicks in, the compressor adds load to the engine therefore the idling will go lower. The FICD sense this then counter by raising the idling speed.
But since you mentioned is after refilling petrol like my SUV then that is not the problem. I suspect something to do with pressure in the tank or system
