light metal live band inside cabin??? er...Can explain more details?
Btw, whar is cabin?
Is it like the sound when the air cond's fan is at MAX speed?
As usual, problem come with new vios
ksb
, Nov 17 2003 09:45 AM, 66 replies to this topic
#62
Posted 20 November 2003 - 02:04 PM
is inside dashboard, nothing to do with fan speed, happen also at low fan
speed. Like flying metal friction like sound, irritating... will try denso
fix like what Vios said previous near Sg Pinang.
#63
Posted 20 November 2003 - 02:28 PM
myawid, yep the sound is coming from the engine compartment, it is like
the radiator/aircon fan switches on and off, but happen too frequent in a
short interval especially when the engine has been heat up by some drive.
#64
Posted 20 November 2003 - 03:43 PM
just off the air-cond and test. then you will know for sure whether the
sound is connnected to the air-cond or not. simple.
i am quite surprised. i thought the vios would be much much better in
quality and trouble free compared to the Protons and the Korean makes.
Seems to be also afflicted by unknow demons
#65
Posted 21 November 2003 - 01:48 AM
ksb,
Understood now, thks.
skmy69,
Fyi, the on and off sound of the fan is normal,in which it is on (`huuun`)
when engine heat up, and off when engine heat low. Have heard it when
driving sometimes about 5 seconds, but not obvious and seldom happen.
I have test put to `P`, pull h/brake, off the radio and turn on the
aircon to minimum, but no `huuuunn` or `hmmmmm` sound in this case.
Any way, i wil keep monitoring it. will update here if any problem.
skmy69,
#66
Posted 25 September 2014 - 04:38 PM
Hi all,
I just purchased my new Vios last month. I found the same problem as what you said:-
** The Air Con sound blow MAX with short interval time, repeating in few second. Actually what is the actual root cause for this? When I complaint it to Toyota, the standard answer to me is " Normal". I have checked with few sc near Penang here, they keep saying this is norm, but noticed other same model vios do not have this type of problem.
Need your help here to advise do you know any solution for this or anyone has been gone thru Toyota to solve this problem?
Appreciate !
Appreciate !
#67
Posted 24 December 2014 - 07:27 AM
QUOTE (smart8929 @ Sep 25 2014, 04:38 PM) <{POST_SNAPBACK}>
Hi all,
Appreciate !
Appreciate !
Your's is a new car so shouldn't be but the symptoms is of the problem is like old car symptoms due to worn out to be either these.
1. Timing belt
2. Timing belt pulley
3. Aircon Belt
4. Alternator.
which causes all the timing of your aircon, engine to run havoc, not in syn and making funny noises. If it is really one of the listed problem, than u must claim from Toyota as it should be under the warranty clause.
