Any of the following problem for M'sia Camry?
mpyw
, May 05 2003 04:19 PM, 15 replies to this topic
Posted 05 May 2003 - 04:19 PM
Automotive Recalls and Technical Service Bulletins for 2002 Toyota Camry
LE Sedan L4-2362cc 2.4L DOHC (2AZ-FE) MFI.
Provided by ALLDATA
Bulletins for 2002 Toyota Camry LE Sedan L4-2362cc 2.4L DOHC (2AZ-FE) MFI
Service Bulletins
TSB Number Issue Date TSB Title PG027-02 DEC 02
Steering/Suspension - Ball Joint Inspection
EG001R-02 OCT 02 Engine Controls - MIL ON/ DTC's Set
NV002R-02 OCT 02 Exhaust System - Catalytic Converter Shield
Rattles
EG002R-02 OCT 02 Fuel System - Gas Cap Sticking
BO017-02 SEP 02 Interior - Seat Belt Extender Availability
EL006-02 AUG 02 Navigation System - Identification Method/DVD
Map Data
AU002-02 MAY 02 JBL Audio System - Popping Noise
TC001-02 MAY 02 A/T - Fluid Requirements
EL005-02 MAY 02 Electrical - Junction Block Connector Update
EG003R-02 MAR 02 Emissions - OBD II Readiness Monitor Drive
Patterns
PG010-02 MAR 02 Engine Coolant - New Color
EG007-02 MAR 02 Valve Cover Oil Baffle - Damage Prevention
EL003-02 MAR 02 Theft Deterrent System - Passive Mode
Programming
SS001-02 MAR 02 Drive Shaft - Nut Chisel Tool
BO007-02 MAR 02 Roof Molding - Deformed
EG005-02 FEB 02 Radiator - Replacement for Towing
BO005-02 FEB 02 Seat (Rear) - Release Knob Sticking/Binding
EL001-02 JAN 02 Speedometer Needle - Resistance to Movement
BO003-02 JAN 02 Trunk Liner - Comes Loose From Rear Seat
Brace
PG008-02 JAN 02 Certification Label - Replacement
Availability
PG009-02 JAN 02 VIN Plate - Replacement Availability
PG007-02 JAN 02 Brake Rotor - Rust Prevention
PG002-02 JAN 02 Service Manual Corrections - Availability
PG001-02 JAN 02 Technical Service Bulletin - Information
ST005R-01 DEC 01 Steering - Vehicle Pulls To One Side, Manual
Supplement
SS009-01 DEC 01 Air Bag - Wire Sub-Harness 8 Required for
Deployment
BO031-01 DEC 01 Windshield Wiper - Identification and
Replacement
BO030-01 DEC 01 Windshield Wiper Blade - Maintenance and
Cleaning
NV011-01 NOV 01 Sliding Roof Sunshade - Crackle Noise
EL010-01 OCT 01 Keyless Entry System -
Identification/Programming
ST003-01 SEP 01 Steering Wheel - Off Center
PG017-01 SEP 01 Disc Brakes - Anti-Rust Cover Removal During
PDS
BO023-01 SEP 01 Seat Belt Extender - Increases Belt Length
PG015-01 AUG 01 Moon Roof - Initialization
PG013-01 AUG 01 Fuse (D.C.C.) - Installation During PDS
(Japan Built)
PG014-01 AUG 01 PDS - Updated Checking Procedures
PG011-01 AUG 01 Front License Plate - Installation
PG008-01 JUL 01 Compass - Initial Calibration During PDS
PG010-01 JUL 01 Door Mirror - Installation During PDS
PG009-01 JUL 01 Rubber Body Plugs - Installation During PDS
Provided by ALLDATA
Service Bulletins
Rattles
Map Data
Patterns
Programming
Brace
Availability
Supplement
Deployment
Replacement
Cleaning
PDS
(Japan Built)
Posted 05 May 2003 - 09:38 PM
guys
my camry seems to have a discoloration of the body paint (winestone
red),particularly at the non-metal parts
UMW guys already took the digi pics, and soon they will come back to
me...of course they still have to repaint the affected parts
rgds
rgds
Posted 06 May 2003 - 08:00 AM
anyway juz send for them to check loh....still under warranty
mah...right...
mah...right...
Posted 06 May 2003 - 10:40 PM
the point is to have the paint defect for a brand new car is unacceptable,
particularly from Toyota.of course i can claim for warranty, which i
already did as i wont let 'em get away with it easily
Posted 07 May 2003 - 08:43 AM
megatnh,
actually you can't blame UMWT for all these loh...coz upon receving your
car did you check ..?? did your Sales ppl check for you..?? these mean
that even yourself oso never take precoution on it loh....
Posted 07 May 2003 - 12:24 PM
Mega,
No surprise !!! UMWT 's ASSB is doing all the assembly and painting job at
Shah Alam.
Technically speaking, you need to have a good quality of water to wash a
bare metal/plastic they called DI water (De-ionized water) before spray
painting. If the quality of the washing water contains ions, they will
stick to the bare metal and this affects the adhesion of paint to metal.
Thats why the paint will come off or in time the whole patch might just
dropped off.
And ASSB is using 'untreated underground well water' for their production,
I think.
Note : Pls do not sue me for the above statement if not correct !!, eh
Unker CHIPS.
Shah Alam.
dropped off.
I think.
Unker CHIPS.
Posted 07 May 2003 - 10:11 PM
meganh,
you are not the only one. my beige altis has "leopard" spots all over the
car. I am making them paint my whole car
shame on UMWT to allow such defective cars to leave the factory without
proper QC check .
proper QC check .
Posted 07 May 2003 - 10:22 PM
this is indeed a worrying situation...
shame on them
i think this is due to the fact that at one time the Camry is hot in demand
which i think it is still is now, that they didn't QC properly. hopefully
this is an isolated case. At least, they admitted and re-painted ur car! good!
shame on them
