Air Fuel Regulator
Phibes
Posted 02 December 2004 - 02:20 AM
Phibes
  • 736 posts
The brake performance question .. no comment on this now .. before I say
anything I need to do some controlled testing, because of the safety
concern and the possible differences between cars and brake systems such as
ABS etc.. , if I find it to be safe and improved I will let you all know,
as well if I find risks I will also inform..
Getting back to the Air Injectors I am using, I believe they can be adapted
for performance applications with a little thought .. for the casual
enthusiest who wants a fast and easy bolt on performance enhancment and
better FC, they should simply install one, understand mine is not installed
as the manufacturer suggests, as I am working towards a higher performance
application, this is why I am facing the issues being discussed. But they
are not all the same.. the ones I am using are I feel are very well built
and more beneficial than say Ecotek or the Compressor thingy with the
mutiple tubes in it..
Peace
Peace
