ERV owner help
Posted 17 April 2008 - 07:42 PM
t5ip top cond bcos i will be using the car mainly long distance trip.
Posted 21 April 2008 - 11:47 AM
You can try by post asking for contact service center in the Swift
section. I think you will get some reply from them.
Since you are travelling outstation most of the time, then this ERV odd
tyre size 165 R14 65 will be difficult to get and also a lot more
expensive than those 15 or 16 ince common size tyre. My father just
change to 165 R14 55 size. It was the Kenari/Kelisa size and actually the
this size has exceeded the 3% rule by what to do. My Father get this size
of Yokohama Ecos (Japan) at RM140/pc (roughly, not so sure)
Update for you. Sat (19/4/08), my father ERV air cond fan break down. Air
cond become so hot and engine also died off while stopping at the traffic
light. After diagnostic, the is was the air cond fan motor that had
spoilt. After dismantling out the motor fan, found out it was a brand
China brand motor. Changed it to Denso (Japan) motor for RM140++.
Actually all the previous problem of RPM low was most likely to be caused
by this deteriorated in the functionality of this motor fan. Will get the
feedback from my father for his test drive in this few days.
FYI, this are the items I bought from PH Auto
Air filter (OEM type) - RM33/pc
NGK BKR6E (Nissan packing) - RM7/pc
Oil Filter (OEM - local) - RM5.50/pc.
Also check out with PH Auto that the fuel filter is located inside the
fuel tank and quite similar situation like my Kelisa whereby in order to
change the fuel filter, you will need to take out the whole fuel tank. So
let it be as it is.
Also checked out the absorber price-all ori, not OEM manufacturer for
this model
Front - approx RM200++/pc (currently no stock. need to order if want)
Rear - RM175/pc
Wah be prepared to fork out nearly RM900++ if want to change the whole
set of absorber.
Thanks
Regards
Poon
Posted 22 April 2008 - 08:00 PM
car?where is their service center?care anyone to help me....
Posted 25 April 2008 - 07:27 PM
so kena damn
Posted 29 April 2008 - 01:41 PM
I have seen the Lion Motor using those scissors jack to raise up the
whole car like the one you can see in the big service center and also
exhaust shop. However I'm not sure whether need to take down the engine
or not but maybe if raise up like I mentioned, maybe replacing of belts
can be done easier.
Regards
Poon
Posted 02 May 2008 - 07:17 PM
system.anything will keep u update.
Posted 27 May 2008 - 07:26 PM
or3speed +od?
Posted 28 May 2008 - 04:45 PM
ERV is a 4 speed auto with OD.
By the way, what you feel when driving the car with the EPS check light
on?. Is it become heavy like those non power steering Iswara?
Regards
Poon
Posted 03 June 2008 - 12:58 PM
low.i m impressed. the weight is about that so is still acceptable.fuel
usage is about 30liter of fuel can go about 350km.wat about ur car? is the
anyway to modify the suspension bcos is to hard on the rear.can we remove
the cone?
Posted 03 June 2008 - 04:09 PM
My father never monitor the fuel consumption, therefore sorry but could
not give you any feedback on this.
From what I check out at PH Auto, only the ori absorber is available for
ERV. No after market supplier is producing for such a small market in
M'sia.
By the way, what is the cone you are refering to?
I also found out during the Gear box flushing and injector cleaning
(using ultrasonic cleaning) at one work shop located in Klang (Teluk
Panglima Garang), according to the foreman, he said that we will need to
take out the engine like what you said earlier to replace the timing
belt. However, he said that the method will be very difficult and
different from the way to take out the engine of Kelisa and Kenari and
Kancil. I think I will inform my father to find out also from Lion Motor
which company has taken over the ERV servicing and maintenance.
Thanks
