wira crystal headlight - opinion
NSX666
, Apr 30 2003 01:33 PM, 7 replies to this topic
Posted 30 April 2003 - 01:33 PM
i was wondering if the wira crystal headlight ( glass) does give a good
focus beam at night? just like the borsch oem headlight.. or it is just a
fancy accessory that does not give benefit at all... other than esthetic
lookk... how much does it cost for a pair togtehr wityh the side signal...
Posted 30 April 2003 - 02:07 PM
NSX666,
I was wondering about the same thing quite some time back. I even went and
see at the acc shop the design of the lamp. It looks too simple when you
compare it to the original crystal headlight design say from the civic or
the perdana. I figured that probably the light will be spread too much and
would not have enough focus. I asked the acc guys and most say not much
diff. but it' not convincing though. Furthermore, check out the material
used on the inside of the lamp, looks a bit cheapo. Hmm, probably will
deform if using brighter bulbs...
My 2 cents
Quah
My 2 cents
Quah
Posted 30 April 2003 - 03:52 PM
Guys, dun change ur OEM 2 crystal coz it's not worth it.
I changed mine n got a free pair of side lamp, but the fact is d reflector
inside burnt 4 only 1 day. Mayb bcoz i used the 90/100W H4, but d H4 din
do any damage 2 my OEM. N the surface of the crsytal is easily scratch
even with fingernail (plastic of coz).
My fren's exp, he bought d crystal (glass) 4 only 1 day, n it was filled
with water d next morning. He said he can even keep fish inside them.
D crystal is just 4 look, not 4 performance. So dun expect them 2 do good
in light spreading/focusing etc. Bosch spent millions 4 d OEM, how much do
u think d manufacturer spent 4 d crystal?
So my advise, dun buy them, unless something happen 2 ur OEM n u wan 2
replace them.
replace them.
Posted 30 April 2003 - 04:02 PM
yes, don't get those crystal lights. It's useless. It's more for looks
rather than function. I have actuarry tot of getting it until i saw a few
Satrias/ Wiras/ Putras using it. The beam couldn't be focused, spread too
much and caused glaring to the oncoming cars. Thus, no matter what super
bright bulb you use, it's will not be bright caused the lights are
spreading all over the place.
Ponder this, Bosch have spent a large sum of $$$$ on R&Ds to produce a
good headlamp....while these backyard factory products doesn't even do R&D
on their products. So which one should be better?
By the way, next time if you want to ask those accesories shop people
whether a product is good or not....forget it, not matter what, they will
tell you that it is good. They know nuts about the stuffs they are
selling!!! I have tested a few guys from Brothers on the Raybrig
bulbs...as you know, they are selling the imitation Raybrig bulbs. I
asked them is this original and they said "Original!! Made in Japan!!".
You think i'm stupid meh!?
Posted 30 April 2003 - 08:33 PM
I changed mine 2 crystal bcoz all my headlamps n side signal lamps broke
in an accident. The price was 1/3 of the OEM (i think).
Now i'm so damn regret about it. Dun change d OEM.
Posted 02 May 2003 - 12:41 AM
ya.. i agreed with wat u all said here... OEM is the best..
but my oem 1 broke when i accident last year... and now my headlamps is
come together with mivec bod parts... not brand new headlamps... it is not
bright enuf since it is too old liao i think.. the plastic become
yellowish oledi.. think to change to proton oem 1... dono how much per
pair..
pair..
Posted 02 May 2003 - 02:13 AM
Plastic headlight sure bcome yellowish after sometime. Even some OEM (of
coz plastic not glass) oso bcome yellowish.
Posted 02 May 2003 - 08:11 AM
on top of that, the chrome part will be faded as well. Guessed we have
discussed this thread in AW quite sometime back again
