Nimota SYM GTS 200 - Problems & Issues
Posted 05 October 2007 - 02:31 PM
Just to start a new topic to only concentrate on problems and issues.
ENGINE SWITCH OFF PROBLEM (September 2007, 1,400 km)
DESCRIPTION: Happens during hard braking and/or at slope (so far, only
downhill).
As of now, it happens both when FUEL GAUGE is low and FULL; hence my
believe it's not the fuel level, but more to the caburator having issues or
design fault (position).
FIX/WORKAROUND: Do not brake so hard : ) - btw, after the engine is OFF,
don't panic... you can restart the engine in a couple of seconds.
Posted 05 October 2007 - 10:59 PM
checked, might be a one off thing.
Posted 09 October 2007 - 11:42 AM
Hi guys, I just got my new GTS last week. thanks to UOLS for having this
kind of discussions so that ppl like me can make decision easier... btw,
i'm still wondering of the O/R or oil reset button function on the meter
panel. does anyone know about this?
Posted 09 October 2007 - 12:19 PM
what the number really is) oil change light akan pasang. then once you
service, then tekan jelah button tu, dia reset for the next 3000 km.
Hehehhehe rasanya lah!
btw, kalau basuh motor jer sure hujan. tension
Posted 09 October 2007 - 04:44 PM
i'll "tekan jelah button tu" when i send my GTS for service tomorrow. What
is yr mileage reading mike?
my advice: tak yah ler cuci moto engkau tu ... dah nak dkt Raya ni... nnt
hujan hari2 engkau jugak yg susah nak balik kampung.
To all muslim... I would like to wish u guys "Selamat Hari Raya". Do lock
yr bike when you go for balik kampung...
Posted 10 October 2007 - 03:18 AM
motor nya! :D cuti tak dapek, tulah dia kerja oil n gas ni. especially
kalau service company.
my mileage? less than 2k! :D nanti lepas 2k service i test the button.
Posted 10 October 2007 - 09:21 AM
moto engkau esok sbb aku nak balik kg... nnt ujan lebat lg susah aku nak
blik kg. muah ha ha ah. mike, moto wat color? Dah buat cosmetic change to
yr GTS? in case if we bum to each other somewhere in KL at least i can
recognize u.
lance, r u around?
Posted 10 October 2007 - 09:48 AM
I will post my "sembang" in the other 2 topics, later ...
Anyway, to clarify the problem. So far, it has happened TWICE.
Once is Fuel at 2 bars and going down slope with hard braking
2nd time was Fuel at FULL and hard braking on level ground
downhill).
Posted 10 October 2007 - 10:29 AM
check yr engine timing? could be yr timing is too low. i've experienced
this before with my elegan.
Posted 10 October 2007 - 10:39 AM
Problems is ...
1st time - engine idle was 2,000 rpm
2nd time - after Liong set it to 1,500 rpm
Not convinced it's related to idle speed ... i could be wrong, but not likely.
downhill).
