Waja 2004- Wheel vibration at 120km/h
edkhan26
Posted 04 December 2004 - 11:17 PM
edkhan26
  • 138 posts
Sent the car for wheel balancing even b4 1000km. More steering wheel
vibration. Is Waja that difficult to balance.
Happened to my Kelisa too which vibrated at the first day at 100 km/h.
Sent the car to almost like 10 times for wheel balancing but the result is
still vibration. Some say tyres, some rims. But ultimately the Rawang SC
(jap who checked my car) says the engine mounting not tightened acc to
specs) After that ok.
Is this happening to my waja again? Checked with my fren who has a waja.
Same problem.
Dun ask me to do onwheel balancing cos it will hurt the tyres badly.
KANASAI967
Posted 05 December 2004 - 01:02 AM
KANASAI967
  • 115 posts
TRY ADJUST THE CAMBER
firezy
Posted 05 December 2004 - 02:09 PM
firezy
  • 21,104 posts
don touch the camber if possible cos your car dem new! normally is
because of the tyres! if done so many times yet to be fix!
maybe they need to added 2 pieces of rubber onto the steering bushes! try
and see how is the result!
KANASAI967
Posted 05 December 2004 - 02:21 PM
KANASAI967
  • 115 posts
MAYBE WAT U SAID IS CORRECT, COZ STILL NEW, BUT LAST TIME I SEND BACK TO
SC TO ADJUST THE CAMBER COZ IS NOT TIGHTEN.... SHAKE SHAKE...
firezy
Posted 05 December 2004 - 06:09 PM
firezy
  • 21,104 posts
if SC themselves do it don ok lar! but tyres shop do if anything happen
or chamber KOYAK then your pocket also KOYAK! Big Smile
fyi, if you using EV comes with stock NCT5 then i will say that tyre is
bery hard to get accurate balance!
blazerSST
Posted 05 December 2004 - 06:23 PM
blazerSST
  • 1,790 posts
Yup still new send back to SC.
LiloStich
Posted 05 December 2004 - 08:29 PM
LiloStich
  • 942 posts
the NCT5 are a little hard to balance... that happen to my dads car...
the wheel was not even round (serious... needed to sd back for calim, his
car was only 5K km then).. he got fed up and changed to fresh new bridgy
GIII.... never complained since...Big Smile
badai
Posted 06 December 2004 - 02:08 PM
badai
  • 106 posts
It's true that WAJA chamber setting is not 0 but -1 coz is't part of
lotus handling stuff? anybody know what is actual WAJA chamber setting ?
thoroubred
Posted 06 December 2004 - 10:00 PM
thoroubred
  • 73 posts
Kalau stering masih bergegar walaupun selepas wheel balancing, pegi kedai
yang boleh buat 'on wheel balancing'.
Tapi dari pengalaman saya, selepas tukar rim ke rim lain yg berkualiti
(yg ada VIA spec).. masalah selesai.
KANASAI967
Posted 07 December 2004 - 12:36 AM
KANASAI967
  • 115 posts
ThumbUpThumbUp
the VIA spec is some quality assurance, similar something like SIRIM,
make sure dont buy JRD... extremely low QC control product...
