DIY power steering flushing
mitsu4g18
Posted 05 December 2005 - 09:51 PM
mitsu4g18
  • 1,891 posts
For all kaki DIY, or non kaki DID who wants to try..
1. Stick up your finger in the PW reservoir filter unit and turn left
2. Remove the filter unit, just like plugging your household socket bulb
3. Use the high power sucking pump, and suck the oil into a transparent
container.
tips,
1.Make sure before topping up during flushing always install back the
filter just to avoid any dirt going into the system..
2.After topping up make sure start the engine for 1 or 2 minutes, for the
pump to circulate the new fuild.. the pw pump powerful you can see the
fliud swirling inside the reservior..and sure nothing is hanging or
blocking near engine prior starting the engine..
3.The fuild capacity is around 0.8litre (in the manual), 3 to 4 times
flushing should be adequate...
4.Don't forget to put back the pw filter..and wash with water any fuild
spillage..
5.Use fluid recommended by manufacture i.a.w with maintenence manual or
equivelent dexron II fluid...
Caution! extra safety precaution should be adhered when handling running
engine.. any mishap arises in the course of exercuting it shall not be
the responsiblity of the author....Smile
cmpong
Posted 07 December 2005 - 12:04 PM
cmpong
  • 481 posts
Hey man, is your sucking pump manual one (not powered by compressor)? if
yes, where to get it...thanks...
upmt
Posted 07 December 2005 - 12:26 PM
upmt
  • 704 posts
buy at fish and aquarium shop
mitsu4g18
Posted 07 December 2005 - 01:01 PM
mitsu4g18
  • 1,891 posts
the pump is the cheapo one.. can get from hardware shop.. I bought it
from supermaket.. plastic dept.. rm6 if not mistaken... mamak roti
usually use this to suck cooking oil... cut the siphon shorter for faster
suction..
asianlover
Posted 07 December 2005 - 02:03 PM
asianlover
  • 246 posts
WAH...Mitsu4g18
Knowing u we shall save a lot of money ThumbUp. But those workshop near to
yr house shall one by one close shop hehehe...Blackeye....Big Smile. Good idea
leh...
mitsu4g18
Posted 07 December 2005 - 11:30 PM
mitsu4g18
  • 1,891 posts
asianlover,
no lar ... I never do for money one ...most of my fren send their car to
workshop also... bcoz I will never do for them, I only show them how to
do it, and they got to hold the spanners and DIY, most of them will get
sick after changing clutch plate.. once they are able to change the
timing belt, the rest is easy... not many people like this job unless for
money or you are really damn crazy hehehe... once you got the taste of
either changing a clutch plate or timing belt.. you would never want to
do it again.. the shop will never close..trust meSmile
gjrforce
Posted 08 December 2005 - 09:54 AM
gjrforce
  • 6,723 posts
hi,
i notice my power steering oil cap's rubber seal are break...it is ok?
mitsu4g18
Posted 08 December 2005 - 03:31 PM
mitsu4g18
  • 1,891 posts
break or just came out from it's slot, try look again & push with your
finger.. the rubber is just to protect from spillage..
gjrforce
Posted 08 December 2005 - 04:10 PM
gjrforce
  • 6,723 posts
some of the rubber seal are tear out and comeout from the slot....
i try to slot it in..but will come out abit after close the cap..
i am worry the air will went it the reservor.
mitsu4g18
Posted 08 December 2005 - 04:40 PM
mitsu4g18
  • 1,891 posts
usually the resevior is not a pressurised one.. it even has a breather
hole in it...
