QUOTE (kiddy @ Sep 20 2009, 09:17 AM) <{POST_SNAPBACK}>
so if the pedal position goes lower means the system got bubbles???..but then how come somtimes i press slight can feel the braking d....sometimes press lower on can get the braking......erm bleed before d....but i think this problem comes after bleeding the brakes........
Does the problem happen at random or at certain condition or driving style?
Also check your piston to make sure none of it is jam.
Jack the vehicle up and rotate each wheel see if they rotate freely.
Overheating pad can cause brake fade.
If it happen after bleeding then my guess is the bleeding was not done properly or the brake hose is already kembang.
However if the brake hose is worn out, it should happen all the time.
Tyres oso plays a huge part during braking.
Cheap tyres wont stop as quick as premium tyres.
The difference is huge.
