Rear disc break
Posted 07 October 2008 - 10:11 AM
break for my persona? mine is bl persona.
Posted 07 October 2008 - 12:04 PM
You may go to any workshop with good quality of servicing work to replace
your drum brake hydraulic mechanism.
If just the drum brake hydraulic mechanism problem, just around RM 50++
c/w labour cost.
Have a nice day.
Posted 07 October 2008 - 12:25 PM
c/w labour cost. "
What is this brake mechanism? And it is so cheap. Just RM50++ c/w labour....
Posted 07 October 2008 - 02:30 PM
choose the brand you prefer.
Posted 07 October 2008 - 04:30 PM
proton man,then he said maybe the drum break got problem because most of
proton persona BL model got this problem. Do you know why this problem
happened?
Posted 07 October 2008 - 11:51 PM
normally due to either the disc rotor uneven surface or brakde pads too
thin.
my car is BL auto, but i faced similar problems during 18,000km or
sumthing like that.
last 2 months the brake pads worn out. and i was caught by surprise that
the mileage was only 25,000km. so watch out if your car also more than
25,000km.
my piece of advice - if you want to have better braking performance for
little money, go for uprated brake pads. i changed to bendix - and quite
happy with it. the steering vibrate also disappears.
p/s but you can go to proton first and complaint about this problem. i
heard proton will give you new discs!! good luck!
Posted 08 October 2008 - 07:41 AM
got the car in may 2008..
how to rectify the drum brake problem?do i need to replace the brake shoe?
Posted 08 October 2008 - 11:18 AM
got problem bro, its idle, bengkok liow or ur caliper almost jemm. rear
drum less headache actually, no burn disc or handbrake loosed. i used to
drive bfr wt drum brake, cz mine also base model, 2 times almost kiss
front car ass, then i upgrade to disc. our car weight about 1.1 or 1.2
tan, so don't follow to closed front car or run over 160kmj, scared might
not enought time to stop d car.
tke care...
Posted 08 October 2008 - 11:53 AM
disc break?i'm gonna check the front disc..
Posted 08 October 2008 - 03:34 PM
i got mine frm my friend in tanjung malim with cost 1200, brand new.
limited stock, 1 booked for 6 months, get it last june. ask from service
center in mutiara damansara, they quote me 2800, rear disc with full abs
module for front & rear.
